Would like one that will reset any found faults or errors, handheld and not bothered about Bluetooth or apps....
Many thanks..
Many thanks..
Highly recommend Bosch Diagnostic Circa 11K
You need to specify the make and model of vehicle unless you're prepared to pay £1,000s if you want to read and clear ANY error codes. For Fiat it has to be either Multiecuscan or Ficom. Both are software that runs on Windows devices and you'll need the correct connector cables and possibly a VCI as well.
If you want a generic reader that will only read the main ECUs there are lots.
In either case you can only clear codes successfully if they related to an intermittent condition that has not recurred, or you have fixed the fault that caused them to appear.
