Rear view/Parking cam (1 Viewer)
Jands
358
565
Specing our future purchase.
Can you get a rear view cam as well as parking cams?
Is it useful or do mirrors suffice?
Also position of screen, as getting a Garmin sat nav as well don't want to have too much in front of me so thought of a rear view mirror screen.
Ideally have the reversing screen on the Garmin but can that only be used with its own camera?
43,286
49,202
The screen on rear view mirrors is tiny. Only a part of the mirror is usually used.
Not sure if the GPS will have the ability to show video and the camera has to get power from somewhere which I doubt the Garmin can supply.
Then it depends on the plugs/sockets, cameras usually use phono type plugs.
In my opinion a camera kit with its own monitor is far superior.
Setting the bottom edge of the camera view as low as possible will assist reversing and the upper camera view should give a reasonable rear distance view at the same time.
You will have a far better rear view using a camera than using door and interior mirrors.
Zigisla
2,576
3,101
Gosport, Hants
Sunlight A72
Getting better month by month.
I have a garmin SatNav with its own CMOS 320 camera mounted on the bumper. It has the parking lines - "Switch offable", so it is easy to park up to a rear obstacle. Not great as a rear view mirror, but certainly enough to check what is behind you - highly required in France.:cautious::cautious: Large 6" screen so easy to see, but you do have to use mirrors, screen and often a "banks-man" / Wife.:rolleyes:
Aug 6, 2013
11,949
16,550
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Rear view mirror monitors are also available that are full 7" diagonal. They clip over the existing mirror or can (in my case) replace it completely. The advantage is that the rear view mirror position is where you tend to glance to check the rear view. This is one with decent resolution:
43,286
49,202
You live and learn. :oops:
Jul 5, 2013
11,719
13,695
Since 2013
Like many other people we have twin rear cameras, fitted by the dealer. One fitting but two cameras, one pointing down for reversing and one pointing rearwards for driving. We also have a dealer fit Kenwood double DIN head unit which has radio, CD/DVD Garmin sat nav and inputs for both cameras. Not sure of the size of the screen, but it is more than ample enough for me.
Jan 31, 2016
1,897
3,372
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
In our current van we have a Waeco camera and 7" display even has audio. Fitted by Hymer when new at extortionate cost no doubt. It is a fantastic bit of kit though. Not sure we'll be fitting one our new Moho though.
filopastry
1,016
1,738
london
littleun
newbie and learning every day
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Rearview camera a VERY useful addition in my opinion. You will find it quite surprising when you see what is behind that cannot be seen via wing mirrors and motorhome rear view mirrors tend to be useless other than seeing what's happening INSIDE the van.
Wyn
Aug 6, 2013
11,949
16,550
Kendal, Cumbria
since 1999
Cheers, damn site cheaper than a Waeco.
As far as I can see most 'branded' camera / monitor kits are identical to the cheaper versions on eBay. They are all manufactured in the Far East. Value-add by UK or brand suppliers is expertise and aftercare. Which simply means that cheap doesn't mean its junk, and equally, expensive doesn't mean it's a rip-off.
