rear springs (1 Viewer)
jenna54
4
6
west dorset
compass navigator vwt4
newbie
i think i need to replace my rear springs van is looking rear heavy problem is where do i go or even look to find out more YES you are right hopeless at anything mechanical
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Google for Grayston spring assisters to see if they do a set of coil spring assisters for your make/model of vehicle.
SandraL
1,373
985
Somerset
Hymer b694sl
First what base vehicle is it?
Does it have an alko rear chassis? If so there will not be leaf springs on rear axle.
Have you weighed rear axle on weighbridge, if so what was weight and what is plated weight? Somewhere you will have a plate that shows front axle weight, rear axle weight, total weight and train weight. Often on crossmember under bonnet. Converter may have added 2nd plate or even 3 rd plate.
With more info am sure replies will come in.
Feb 27, 2011
14,710
75,765
UK
Self Build
If you are on the original chassis (not alko) Then I can highly recommend Jones Springs.
http://www.jones-springs.co.uk/
I bought a set of 2 leaf heavy duty springs for my Fiat Ducato. My Garage charged my £50 to fit them.
The difference it made was incredible.
People advised I bought spring assisters or air suspension. But I felt this would just be masking the fact that the original springs were knackered and not up to the job of being at full load 100% of the time. The new springs have now been on for 3 years and the back end is still as high as when they were first fitted and looking very perky (y)...
jenna54
jenna54
4
6
west dorset
newbie
thank you gromett i have had someone look and they are going to b reeplaced now
