Rear light bulb replacement
  • Thread starter Thread starter 2657
  • Start date Start date
2657
Any of you knowledgeable Globecar owners know how to access the rear lightbulbs?
I assume the lens has to come out but I can only feel one nut through the single small access hole, and this is not easy to get at.
I cracked a lens with the bike rack which will at some point need replacing which set me to thinking about replacing bulbs.
I assume you are on the left hand/ passenger side
If you take out the gas bottle there is a small panel held in with two screws that lets you get access to the other fixing nut.
Be careful you don't drop the nut as its a real pain to retrive it
On mine there is only one hole in the bodywork with limited access on both sides the rest of the body work is covered with trim.
I thought it unlikely that there would only be one retaining nut on the cover but there is no access to anything else without destroying some interior trim.
The cracked lens is on the offside, my Globestar is a different layout to most, the shower/toilet area is at the rear.
