I have a Domentic Air Conditioner B2200 has anyone ever re-gased a sealed air conditioner using a saddle valve to top up there system.
Probably not normally, but old systems do develop refrigerant leaks and they can all be fixed and recharged.Hi
I have the Dometic Fresh light, i contacted Dometic and was told that it was a sealed unit and does not require servicing of any description
I used to fit these on fridges with no gauge port.
Doubt it. Depends on age but might be R410a, it will be labelled up somewhere.Do they use the same gas as car a/c units the 134a gas
We have the fresh jet and our instructions says it does need to be topped up so now really confused.
Yes go for it any questions just ask away. First job, stick some gauges on it, or at least a [Blue] suction low side gauge and run the system (that"s if it will run, might not if there's bugger all in it and it has a psessure switch)I will keep you all posted as it's worth a punt rather than buying a complete new system. It's not working so what have I got to lose ?
It works fine just not getting cold enough so I think just a top up will be ok.?
