When we had our annual habitation service, one of the tests carried out was measuring the speed of the RCD cutting out (or on if that’s how it operates). The measured time (I don’t recall the specific time) was said to be too slow. The technician (and they really are technicians) switched the RCD several times measuring the response time each time and the readings improved in terms of the time time taken to operate.
I’ve read that one should operate the RCD every time you use hook-up. Is there any routine maintenance one should carry out to this item?
