Razor sharp Alde heating fins. Any ideas how to cover them to save injury? (2 Viewers)
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
Like a lot of people I have Alde heating in the van, and in a couple of areas they have horrifically sharp edged aluminium fins on the pipes to help dissipate the heat. I have cut myself several times trying to put things in the underbed storage compartment on my Bailey, and to be honest cannot believe that a reputable company such as Alde can manufacture such a dangerous product or that a motorhome builder (I know Bailey are not the only ones that do it) can fit them in an exposed position where they are likely to cause injury.
I have been thinking for a while how I can fit some kind of protective strip to the bottom of these abominations to lessen the chance of cuts, my ideas having ranged from simple gaffa tape to more complex aluminium strips fitted to brackets, but before I do anything, has anyone else got an idea? I even thought Bacofoil along the bottom might be a good heat reflector as well!
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Mine are all boxed in in cabinets with grills on the top, so sorry I cant help.
Jul 27, 2010
704
1,452
Farnham Surrey
Bilbos Nexa
on and off since 1980
You could probably fit the guards designed to protect electric tube heaters, stop being able to touch them but not restrict the heat output.
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
On sale in Aldi, ribbed silicon tubing that is slit down its length, you slide these onto the front of oven trays to prevent burning yourself when removing stuff from the oven, I would think these would be ideal for the purpose you require
Jackyboy61
124
170
North Wales
Low profile
Polystyrene roof insulation ,cut into strips then use a blob of gripfill here and there then rub polystyrene onto the sharp fins and let it set.(use the solvent free gripfill otherwise it will eat the polystyrene )
BobtheBass
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
Thanks for the ideas. I have contacted Alde to see how much their covers cost, but I think I will visit their namesakes at Aldi to see the silicon tubing as I am pretty sure it will be cheaper!
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
11,953
16,570
This stuff:
Cut with scissors, easily bent. Either screw to floor at each end or nylon tie to heating pipe. (The link is the first I found so I'm not recommending them as a supplier - although their price looks sensible)
19,346
30,234
Our Alde fins are all built in as well so I think your gripe is with your converter rather than Alde.
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
Here you go, this is what your looking for, pack of two I think they were about ÂŁ2.40
BobtheBass
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
This stuff:
I have ordered some ally mesh to try first. It looks like it may work
17,630
43,277
push on silicon edging 5 m packs. just cut to length and push over the sharp edges
Badknee
7,407
412,730
notloB
Vantage Neo
Living the dream.
They work well, Mrs Badknee bought some to stop rattles in the oven lol.
Bertie Bassett
2,743
8,702
since 1988
Good pointer Gooney, Mrs BB task for tomorrow!(y)
canopus
6,139
10,257
rural Lincolnshire
Carado CV640 Pro
I think your gripe should be with Bailey the converter not Alde. Give Bailey a bell and mention elf n safteee and they might come up with a solution PDQ.
BobtheBass
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
Already emailed customer services. Just waiting for a response.
