Already updated vehicle to 3850kg 1850kg on front 2000kg on rear
I need to increase rear to 2250kg how can I achieve this
It is air assist on the rear, heavier springs on the front and bigger tyres. I had it done last year. SVTech do the calls, Dave Newell did the workAlready updated vehicle to 3850kg 1850kg on front 2000kg on rear
Different motorhome but it makes no difference, it’s the chassis that’s the important bit.Was this on same model I would be interested much was it to do and who completed the work
You need to check which chassis you have. The chassis will determine if you can upgrade further.Was this on same model I would be interested much was it to do and who completed the work
It’ll cost £1600 to £2000 to do an Alko and there aren’t any DIY kits. Be careful who you choose to do the work. We chose AS at Warrington, highly recommended, even though they are across the country and there are fitters a lot nearer to us. I stayed overnight nearby, arrived with them at 9am, spent the day in Warrington, had a long lunch, and picked it up about 4pm. They gave me a lift into Warrington and collected me.I have an alco AMC chasis
If it's a light not sure can upgrade axle weight we cannot upgrade ours abive 3850I have an alco AMC chasis
Ours is on the light chassis and has been upgraded, on the rear axle, to 2240kg from the standard 2000kg by fitting air assist and higher index tyres. Even though our front axle is rated at 1950kg we still have to stick to the 3850kg overall weight. We upgraded the rear because we were always on or above the limit, but the results are much better rear suspension that feels like it is working properly, reduces swaying and is more comfortable and quieter.If it's a light not sure can upgrade axle weight we cannot upgrade ours abive 3850
I think we could transfer some weight from front to back making frint 16850 and back 2200 fitting springs and air assist as well as tyres but decided for cost not worth it. We inly just manage front as it is at 1850.
speak to Svtech
Hi Hettie thanks for clarification as I thought does seem an expensive job but if needed it's needed. With 4 of us we struggle with 1850 at front...Ours is on the light chassis and has been upgraded, on the rear axle, to 2240kg from the standard 2000kg by fitting air assist and higher index tyres. Even though our front axle is rated at 1950kg we still have to stick to the 3850kg overall weight. We upgraded the rear because we were always on or above the limit, but the results are much better rear suspension that feels like it is working properly, reduces swaying and is more comfortable and quieter.
I think ours is the AMC35L, don’t know if there’s much difference to the 37 but they are both the light chassis.Hi can I ask what air assist did you fit and how much and where
We have Alco AMC 37L chasis
Personally I would rather travel several hundred miles to get this one off expensive job done properly than choose a company just because they are near by.anyone who can do in Essex or near
