Radio speakers (1 Viewer)
Keith E
108
56
Hello again.
After the fiasco with the faulty radio I've had a replacement fitted by the stealer.
It took a while, it came from ebay then had to go to Torquay, from the North East, to be recoded.
I was up at the moho last week and whilst I was there I turned the radio on but got no sound from the right hand front speakers, which is the reason I was faffing around with the original in the first place.
My first thoughts were dodgy wiring/connections but I then switched off the engine then restarted it an lo and behold, the speaker started working again.
Has anyone else had this or can anyone suggest what may be the cause?
2012 Boxer with the bog standard radio.
TIA
Misterg
221
213
N Wales
Self build PVC
It could still be dodgy connections. Not sure which version of the radio that you have, but the Uconnect 5 (and probably earlier ones) checks the speaker wiring when it is powered on and if it detects a fault (short circuit or high resistance) it disables that channel - so if there's an intermittent fault that's present when the radio is powered up it will disable that channel until the radio is turned off and on again.
I'd be suspicious of the door speaker if it's the original - they're pretty erm.... cheap...
MarkP
28
3
Northern Ireland
Peugeot Elddis
1 year
Apologies I'm no use to you but you might be able to help me!!
I also have a 2012 Boxer which has been unable to hold a radio reception since we got it, I just haven't got round to looking at it tbh. I have been told though that the aerial is linked into the wing mirror - do you know if this is correct?? There is no external aerial visible...
Keith E
Keith E
108
56
Mar 23, 2012
9,089
29,662
sleights
c class
Our RH door speaker tends to cut out sometimes if I turn up the volume it starts again its very annoying. I thought it was the radio sometimes cutting out but now think its probably the speaker probably just sometimes sticks.
