Q please (1 Viewer)
Feb 22, 2011
9,762
20,113
Newcastle under Lyme
Hymer B544 A Class
Since 2015
When on gas, does having vent fans running to disperse heat make it more or less effective at cooling ?
Jul 5, 2013
11,722
13,698
Since 2013
It depends on where the fans are. If they are at the top of the cavity behind the fridge and blowing air out then it makes the fridge and freezer work much better
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Yes, but ONLY in hot weather. Accidently had ours on once in April & the freezer defrosted.
Figaro
Feb 22, 2011
9,762
20,113
Hymer B544 A Class
Since 2015
They're at the top vent blowing out.
My fridge is playing up on gas and the only way i know it's working is to feel the flue vent to see if it's hot. But with fans blowing I can barely be felt.
Anyway I've rigged up a remote digital thermometer to put in the freezer and it seems to be ok.
33c here in Wertheim am Mein !
43,296
49,283
Let's see if I got this right......
In cooler climes the burner gases convect quite rapidly (cooler ambient air, warm exhaust) drawing heat from the fridge coolant.
In much warmer climes the ambient air temperature and exhaust gas temperature are much closer matched so the convection is much slower drawing less heat from the fridge coolant.
Having fans running draws air faster through the cavity area and faster moving air is always cooler than static air (think standing in front of a fan on a hot day) so the exhaust gas rises faster and draws more heat from the fridge coolant.
Physics dear boy, physics.
2657
Not sure about the moving air being colder than static air, the only reason the air from a fan feels cooler is because of evaporation from the skin and replacing air warmed by our body with cooler ambient air, unless of coursevthe ambient air temp is greater than 39.8°C.
A draught created by a fridge fan moves heated air from the fins of the coolant radiator and replaces it with cooler ambient air more efficiently than convection currents, think car radiator.
At least that's my attempt at the physics.....but I did fail A level physics:)
43,296
49,283
OK, so using that basis you don't actually need gas as the air will remove the heat by evaporation. :whistle::D
When I was at school A level was something you used to check if something was sloping.
2657
Burning the gas causes the refrigerant to evaporate in the sealed system and then condense in another part, taking heat away from the air inside the refrigerator, I do not understand that process fully but I do understand that the heat withdrawn from the refrigerator has to go somewhere and that somewhere is the finned radiator on the back.
The heat is exchanged from that radiator to the surrounding air which will rise by convection to the top vent and be replaced by cooler air through the bottom vent, in warm weather this process is aided by increasing the air flow over the fins with the fans.
The gas is burnt to provide an energy source to drive the system, and is exhausted separately from the coolant air.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Physics, "Who the hell is Physics"or was it Alice
2657
I believe it is all down to latent heat folks... latent heat.
(I left school before 6th form though.)
JJ :cool:
You may be right......I would need to look it up and then would probably be no wiser.........I was good at sums though:)
Reactions: JJ
