PWM charger help please (1 Viewer)
Shaun929
118
223
Sunny isle of axholme
Carthago Malibu I500
Late 2018
In my van there is a EP solar controller and on the display it has a flashing red ‘H’ which I have never noticed before and when I looked at my battery monitor it’s not charging the hab batteries to full.
I have done a google search and cannot find any reference to a flashing H on this controller. Anyone know what this means?
I have 2 100watt solar panels and 2 hab batteries.
Shaun929
Shaun929
118
223
Late 2018
Cheers, I couldn’t find that info. So is this normal for it to overheat? It says in the manual it stops charging when it gets to 85 degrees! Do all solar chargers do this?
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Most should yes, it depends on the ambient temperature inside the van. They all get warm when charging. Mine are a Votronic and have fans, the bigger Victron ones have huge heat sinks.
I would say, given the weather it is nothing to worry about.
Shaun929
Shaun929
118
223
Late 2018
I think this solar controller has had it, its just flashing red all the time now and not charging the batteries up. I am thinking of buying a dual votronic 350 is it just a matter of swopping the wires over?
Apr 27, 2016
6,857
7,963
Manchester
A class Hymer
Since the 80s
Yes, but connect them in the correct sequence, so the controller recognises the battery voltage: Leisure battery first, then solar panels. Connecting the solar panels first might cause problems.
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Yes, I should have mentioned that. Sorry.
Shaun929
Shaun929
118
223
Late 2018
So would it be engine battery after leisure then solar?
53,315
149,512
Those controllers are not very reliable, helping Funsters out at a meet eairler in the tear I came across two faulty ones.
I would replace it with a decent MPPT one like a Votronic or Victron.
Shaun929
Shaun929
118
223
Late 2018
Thinking of ordering a Votronic 350, I only have 200w of solar but looking at adding another 100w in the future. Will this be ok to fit the 350 and just change the fuse down or should I fit the 250?
