Push Fit Mixer Tap (1 Viewer)
Stewart57x
Horndean, Waterlooville, UK
Itineo CM660
since 1990
I have a mixer tap on a 696 Zefiro Roller Team Motothome and the tap is leaking and needs replacing. It is connected via two push fit connectors onto 12mm pipe. The tap make is Argo, but I don't mind getting another make - does anybody know where I can source one?
Thanks,
Stewart
Sep 10, 2012
2,148
3,919
worcester
Sunliving van
Just do a search on the bay for caravan or motorhome tap to find something similar.
Or go to your local showroom and pay 2 or 3 times the price.
Might be worth removing the leaking item to compare with the pictures and check if it's got a micro switch.
Pugsy
520
1,390
D&G
Van conversion
Since 2012
Something like this.
Stewart57x
Stewart57x
Itineo CM660
since 1990
Thank you for the advice. I did take the tap off and looked for similar and found one on Amazon, but it came with a screw fix - I hope I havw now ordered an adapter that can push fit onto the pipes
MattR
4,131
40,646
Beds
Panel van
Years
Thanks,
Stewart
Where is the tap leaking? Some can be fixed with replacing the cartridge.
Halling, Rochester, Kent.
R'team Zefiro 685
Hi Matt, Berni,
Can I join this thread, please.
I've just removed my basin tap from our Zefiro 685, because similarly to Stewart's, it was leaking, with a constant slow trickle. At the end of last year, it was just a slow drip. You mention replacing the 'Cartridge'. Which I take it is the inner plastic bit? I can't get mine apart and have scratched it to bits trying to dislodge it, so I think that's a no go.
I see mention of a 'micro switch', which I believe are on some. Before I order/look for a new one. How can you tell if it has a MS? Wiring?
Thanks,
Paul.
2,148
3,919
worcester
Sunliving van
U will have to get to the bottom of the tap and if 2 wires disappear inside it's a microswitch. Might need a mirror or and torch to view underside .
That's assuming no one has upgraded your system to pressure pump.
R'team Zefiro 685
Thanks Berni,
I've got it all apart already and there's definitely no wires. It looks like a standard Domestic basin tap, only going into 10-12mm push fit tails.
I'm pretty sure we have a presume pump system, as I had to semi dismantle the tap on site, goose-neck the flexi-tails, to stop the leak, as without the pressure, we couldn't get hot water in the shower, kitchen sink.
Thanks again,
Paul.
