Pump
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
pump has packed up on our burstner. No power at pump connections with all the taps open
I do have power on the pump feed at the ebox
I assume theres a point where all the micro switches come together and make or break the supply possibly a relay anyone ever found it
I would have thought the relay would have been inside the EBox, you haven't switched the pump off at the digital display panel by accident have you ?
Just had a quick look at my old eBox circuit board and tracing the tracks from the pump fuse, would suggest that the little box, top centre, is the relay for the pump ?
New relay is £2.99 on a slow boat from China https://www.ebay.co.uk/i/2027533137...7779&msclkid=a561151ec6e91ff506aa4a32c62bb093
just checked with apuljacks the micro switches are independent to the e box which provides a switched supply via the control panel. Ive checked and there is power out of the ebox for the pump looks like i will have to try and follow a tap wiring to see if it commons somewhere .
I think there has to be a relay as the pump supply is a 20 amp fuse and the tap wiring much smaller will test at a tap to see if theres power on the micro switch circuit tomorrow
