Hi everyone. For some reason when running my tap the water is pulsating.... any clues please
Sue
Sue
When I fitted our new pump the instructions said open the tap less than half and the pump should come on but stay off for 2 second periods. There's an adjustment on the pump pressure switch but as mentioned above, there is usually an anti-surge damper on the pump outlet which stops the fast cycling on and off.So pump is pulsating but only on the hot tap? Don't understand the technical comments above....sorry technophobe do I need to get someone to look at it? Only replaced pump last year. Travelling in republic of ireland a moment
If it's a microswitch system it will have a submersible pump and they produce a constant flow with no surge.Curious how it's only doing it on the hot tap you could possibly have a microswitch system and the hot tap microswitch is faulty? See if the bathroom hot tap does the same
Oddly the same thing has happened to us. We replaced a leaky pump and now we have a pulsing hot tap … and only the bathroom sink. (Furthest from the pump.)Only replaced pump last year.
Not had a replacement pump but it is only the shower in ours that pulses which is the furthest from the pump and boiler.Oddly the same thing has happened to us. We replaced a leaky pump and now we have a pulsing hot tap … and only the bathroom sink. (Furthest from the pump.)
It’s a little irritating but not a disaster so we’ll live with it until I have a quiet afternoon and I can break it properly!!
Same here. It's done it from new. It's been back to the dealers twice and is going back again, it's the noise it makes that's the worse thing. The pump shakes.Haha .... when I put all taps on it doesn't do it... I think it air... my thoughts are open tank outlet valve and drain down completely... question how do you fill more carefully??( previous quote) I'm. Travelling in the van so need to top up
Yes I think the anti -surge damper is in actual fact an expansion vessel ! And does exactly that ,not to produce a steady flow of waterWhen I fitted our new pump the instructions said open the tap less than half and the pump should come on but stay off for 2 second periods. There's an adjustment on the pump pressure switch but as mentioned above, there is usually an anti-surge damper on the pump outlet which stops the fast cycling on and off.
I think it might be your drawing a greater volume of water , and the deferential switch is not pulsing the pump on and off, or possibly the pre charge pressure in the expansion vessel has depleted and needs recharging ?Haha .... when I put all taps on it doesn't do it... I think it air... my thoughts are open tank outlet valve and drain down completely... question how do you fill more carefully??( previous quote) I'm. Travelling in the van so need to top up
Sorry hadn't realised it was only hot water ! I don't think the op mentioned that in opening post ?If it was the pressure vessel, why is it only effecting the hot supply?
That’s a good shout! Restricted flow rateJust had a thought... Ours has got gause/filter things on the tap outlet and they got semi blocked after 5 years with limescale etc. Check yours is OK,
They just screw off the end of the taps.
Sue, don't be spending your hard earned on calling anyone out, until you have explored and triedWell guys thank you as usual it's obviously technical will hopefully get an engineer to site to fix....anyone know of any up west coast of ireland that will come to site?
When my frost protection dumped all the water I just closed the valve and filled the tank again. I got a lot of coughing and spluttering which has presisted in the hot water and the toilet flush is weak. I'm pretty sure there are threads on here about how to refill without air blocks but I can't search until tomorrow at least. For mine I will empty again and then refill with the drain valve open and run all the taps until the water comes out freely.Haha .... when I put all taps on it doesn't do it... I think it air... my thoughts are open tank outlet valve and drain down completely... question how do you fill more carefully??( previous quote) I'm. Travelling in the van so need to top up
