Pros/cons of uprating weight from 3500Kgs
JohnJan
England
PVC
Since 2011
Having read various threads which mention uprating, I'm in two minds about doing this. Pros are clearly more personal weight allowance, cheaper road tax and staying within law. Cons are speed and lane restrictions. Has anyone actually been stopped and charged with being over loaded? Or convicted? Is there a tolerance of 10%?
TIA
I possibly drove for 9yrs overweight as unbeknown to me the previous owner had downplated the van, only found out when I went to uprate it.
So, over 3,500kg you need the C1 licence, if over 70 you need a medical, also there are restrictions if you are in an LEZ, I had a Euro 3 engine which would have meant the addition of expensive emission filters if I updated, so check that out. There are places you can’t go if over 3.5T, that’s my input ?
What are the speed and lane restrictions as I was not aware of any for up-plated motorhome weights unless you were already over the 3.05 tonnes maximum unladen weight.
Motorhomes or motor caravans (not more than 3.05 tonnes maximum unladen weight)30 (48)60 (96)70 (112)70 (112)
Motorhomes or motor caravans (more than 3.05 tonnes maximum unladen weight)30 (48)50 (80)60 (96)70 (112)
Wot e Z.
Ian
That 3.05t MUW figure only relates to the UK but you are correct (I hope!) in your assumption that up-rating doesn't affect the MUW and thus speed limits in the UK.
In Europe they use MAUW to decide speed limits as well as other restrictions, which is the origin of the magic 3500kg. France recently issued a blanket speed limit of 80kph for vehicles over 3500kg, except on motorways, so that needs to be considered by the OP.
Personally being over 3500kg doesn't really bother us as we're never in much of a rush - if we are we'll use the autoroutes.
Having driven both.
Over 3500kg the issues are speeds and restrictions on where you can go
If you dont need to do it, I would not do it
Also - when you come to sell it, you will be limiting your pool of buyers.
Remember no one under the of 40 can drive vehicles over 3500kg on a normal licence
However, if up rated, it can always be down rated when it's time to sell if that's an issue.
I was in France a few weeks ago and the dreaded 3500kgs speed sign of 80kph is everywhere. My Mass in service weight is 3040kgs and I am assuming that is also the Max Unladen weight(unless you can tell me otherwise) so there is no difference actually. I thought I was in the sub 3.05 tonnes until I looked at the log book.
Its 5% tolerance on weighbridges per axle according to govt websites, you just have to hope that the weighbridge is not -5% when you weigh :)
If your Mass in service weight is 3040kgs then you are below the 3.05 tonnes (3050kgs) threshold then for the UK.
It's the section f1 Max. permissible mass or the section [Y] revenue weight on your V5 that will govern your travelling in France.
Where does the log book show this please? I seem to only have revenue weight, max permissible mass and towing weights.
Section f1 Max. permissible mass on V5's is often blank, but if there is a figure in it, it must match the section [Y] revenue weight.
Thanks but the sub 3.05 tonnes relates to maximum unladen weight which doesn’t seem to be in the log book.
Surely in France they will simply check the van's weight plate which will show over the 3500 MAUW.
I have just reclaimed my grandfather rights which I lost after turning 70, and have been through this same question. There seem to be several points for up-plating:
1. Lower road tax.
2. Higher weight limit
3. No change for speed limits in UK if unladen weight is under 3050kg
However the downsides are:
1. Lower speed limits abroad as they work on the all up weight.
2. Possible problems with recovery cover due to the higher weight.
3. Many restrictions in France going through towns and villages with a weight limit of 3500kg.
For me I probably won't up-plate, because now having the C1, they can't do me for driving outside the restrictions of my driving license if caught overweight. Also, if weight checked, and bearing in mind the 5% tolerance, then I can simply dump any fresh water and that should bring me below.
Please define these speed issues as you see them then.
CountryMotorhome WeightMotorwayNon-motorway roads
Austria
Caravan Motorhome Speed Limits Austria
Motorhome weighing under 3.5t81mph, 130km/h62mph, 100km/h
Motorhome weighing more than 3.5t50mph, 80km/h44mph, 70km/h
Belgium
Caravan Motorhome Speed Limits Belgium
Motorhome weighing under 3.5t74mph, 120km/h56mph, 90km/h
Motorhome weighing more than 3.5t56mph, 90km/h56mph, 90km/h
Croatia
Caravan Motorhome Speed Limits Croatia
Motorhome weighing under 3.5t81mph, 130km/h56-68mph, 90-110km/h
Motorhome weighing more than 3.5t56mph, 90km/h50mph, 80km/h
Czech Republic
Caravan Motorhome Speed Limits Czech Republic
Motorhome weighing under 3.5t81mph, 130km/h56mph, 90km/h
Motorhome weighing more than 3.5t50mph, 80km/h50mph, 80km/h
Denmark
Caravan Motorhome Speed Limits Denmark
Motorhome weighing under 3.5t68-81mph, 110-130km/h50-56mph, 80-90km/h
Motorhome weighing more than 3.5t44mph, 70km/h44mph, 70km/h
Germany
Caravan Motorhome Speed Limits Germany
Motorhome weighing more than 3.5t62mph, 100km/h50mph, 80km/h
France
Caravan Motorhome Speed Limits France
Motorhome weighing more than 3.5t68mph, 110km/h50-62mph, 80-100km/h
Hungary
Ireland
Caravan Motorhome Speed Limits Ireland
Motorhome weighing under 3.5t74mph, 120km/h37-62mph, 60-100km/h
Motorhome weighing more than 3.5t50mph, 80km/h37-50mph, 60-80km/h
Italy
Caravan Motorhome Speed Limits Italy
Luxembourg
Caravan Motorhome Speed Limits Luxembourg
Motorhome weighing more than 3.5t81mph, 130km/h56mph, 90km/h
Norway
Caravan Motorhome Speed Limits Norway
Motorhome weighing under 3.5t56-68mph, 90-100km/h50mph, 80km/h
Motorhome weighing more than 3.5t68mph, 110km/h68mph, 110km/h
Portugal
Caravan Motorhome Speed Limits Portugal
Motorhome weighing under 3.5t74mph, 120km/h56-62mph, 90-100km/h
Motorhome weighing more than 3.5t62mph, 100km/h44-56mph, 70-90km/h
Slovenia
Caravan Motorhome Speed Limits Slovenia
Motorhome weighing under 3.5t81mph, 130km/h56-62mph, 90-100km/h
Spain
Caravan Motorhome Speed Limits Spain
Motorhome weighing under 3.5t62 mph, 100 km/h50-56 mph, 80-90 km/h
Motorhome weighing more than 3.5t56 mph, 90 km/h50 mph, 80 km/h
Sweden
Caravan Motorhome Speed Limits Sweden
Motorhome weighing under 3.5t56-74mph, 90-120km/h44-62mph, 70-100km/h
Motorhome weighing more than 3.5t56-74mph, 90-120km/h44-62mph, 70-100km/h
Switzerland
Caravan Motorhome Speed Limits Switzerland
Motorhome weighing under 3.5t74mph, 120km/h50-62mph, 80-100km/h
Motorhome weighing more than 3.5t62mph, 100km/h50-62mph, 80-100km/h
The Netherlands
Caravan Motorhome Speed Limits Netherlands
Motorhome weighing under 3.5t81mph, 130km/h50-56mph, 80-90km/h
& the allowances & limits apply specifically to commercial vehicles. For plg etc; they are expected to apply common sense & just give a warning, get weight below the MPM & send you on your way.
I have G. Mass in service of 3040, nothing in F.1 and no limits on braked or unbraked trailer(space is blank) And no Revenue weight in Y?
Is a PCV Citroen Relay L4H2
I'm not to sure the wife is going to be to happy about getting out and walking though. ?
Oh dear! That sounds like the start of something unpleasant coming your way!! Good luck;)
MY OH is OK, we carry a folding road legal mobility scooter for her in the back. :Grin:
