Propane Regulator
Discussion in 'Fridges & Ovens' started by Manic, Jun 27, 2018.
  1. Manic
    Manic Funster
    Nov 4, 2011
    1,740
    Uk
    Ratings:
    +3,077
    I’ve noticed when using one off our gaslow bottles both with its own regulator, the hob is sometimes hard to light.
    Been looking at regulators and see some are quoted at 4kg/hour and some 1kg/hour, I didn’t know the came in different outputs, both 37mbar.
    So which ones to get?
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    34,566
    YO11 2BD
    Ratings:
    +31,948
    I suggest the hob ignition system is poorly designed or faulty and nothing to do with the regulator.
  3. SandraL
    SandraL Funster
    Jan 24, 2012
    605
    Somerset
    Ratings:
    +472
    Depends on how many gas appliances you are running. If you have gas heater, gas oven and hobs running then the 4kg per hour would have no problem supplying the qty of gas. The 1kg per hour might struggle. If you get the manuals out they usually detail the quantity of gas the appliance uses per hour on max. You can then work out your max demand and buy the regulator that suits best, ie slightly higher than your max demand.
    • Thanks Thanks x 1
  4. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    4,734
    Essex
    Ratings:
    +6,360
    I thought the van has its own regulator without the need for another?
  5. walburga
    walburga Funster
    Aug 20, 2007
    398
    Leyland
    Ratings:
    +199
    I think using a bottle top reg at 37 mbar will 'over gas' your system, and will result in the fridge 'roaring', with accompanying sooting up of the flue / jet....I did it on a van and that's what happened.
    You may also notice a slight blackening (sooting) of the pans on the hob.
    Vans, post 2002 (approx), were fitted with bulkhead regs at 30 mbar, and appliances where then jetted to suit.
    Allen
    • Thanks Thanks x 1
  6. mitzimad
    mitzimad Funster
    Jan 28, 2008
    5,175
    walthamstow east london
    Ratings:
    +8,232
    depends on the age of the van and the apliances fitted
    • Like it Like it x 1
  7. scotjimland
    Jul 25, 2007
    32,027
    Ratings:
    +35,737
    Suggest you change the regulator to a 30mb bulkhead model.. I recommend Clesse .. this has been the standard pressure for both Butane and Propane in caravans for many years..
    it may not resolve your problem.. but at least you can eliminate any issues with the old 37mb regulator ..
    I had a Hymer, same year and it had one fitted when I bought it..
    • Informative Informative x 1
  8. Manic
    Manic Funster
    Nov 4, 2011
    1,740
    Uk
    Ratings:
    +3,077
    I wouldn’t it’s the hob as it’s only 4 months old, the hob that is, and it’s only when one certain bottle is used.
    Thanks for you thoughts anyway.
  9. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    3,237
    Warwickshire
    Ratings:
    +2,637
    Assuming you are talking about the Hymer (B544?) in your avatar, doesn’t it have a bulkhead regulator as Theonlysue said? Or do you have some alternative installation? Mine used to have the original Truma Trionic regulator system, fitted by Hymer and fed by two Gaslow bottles, but when that failed I had a Clesse (Gaslow) regulator and two-way changeover fitted to replace it. Not sure I understand why each Gaslow bottle would have its own regulator.
  10. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    16,858
    E Yorks
    Ratings:
    +30,069
    Sometimes people use bottle top regulators rather than bulkhead regulators and I think that's what the OP has, first thing is to eliminate it being a bottle and/or reg fault so I would swap the regulators round and see if the bottle that's not giving out enough gas works okay, if so it's definitely the regulator, if not then it's the bottle. I can't see why it would be the hob seeing as it's okay with one of the bottles/regs.
    Another thought ... it could actually be the pipe if it's got a partial blockage ... so once you've done the above and assuming the bottle is okay, examine the 'faulty' reg/pipe combination and see if you can see anything wrong.
  11. Manic
    Manic Funster
    Nov 4, 2011
    1,740
    Uk
    Ratings:
    +3,077
    No it didn’t have a bulkhead regulator when we bought the van in 2009, just bottle regulator. So when I fitted the Gaslow i just followed that and fitted a regulator to each bottle and it’s worked fine until recently.
    Have you a photo of your setup.
    Yes i think swapping regulators would be a good idea.
  12. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    3,237
    Warwickshire
    Ratings:
    +2,637
    Here is my present installation. The pipe work on the left of centre at the back, with a union that has a blob of red paint on it, is the original feed to the van. That pipe comes from the bottom of the regulator (round and golden) travels down a bit then does 3 90 degree turns back up to the union. All that is original so when I had a new regulator and changeover unit (above the regulator) it simply coupled on to the original pipe work. It’s all a bit tight but it just goes in.
    I decided on a Gaslow / Clesse regulator as they have a 5 year guarantee and the replacement Truma regulator (which is what Hymer fit nowadays) has a history of failure.
    • Thanks Thanks x 1
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
