Steve and Denise
So I got to thinking I could cut my own down from110cm to 80cm so removed it today ready to cut .
So fingers crossed what is the worst that can happen
View attachment 183979 View attachment 183980 View attachment 183981 well after looking for the most elusive 360 degree 80cm table I found one for a mere £1500+vat
As a matter of interest Steve , could you please let me know where you found this one.well after looking for the most elusive 360 degree 80cm table I found one for a mere £1500+vat
Yes 150mm off each side so I can keep the 300mm centre which stays underneath and use if needed I will have to cut the under side edge to allow the room for the centre leaf to stay.@SteveandDenise can I ask what might seem a daft question.
Is the middle piece a loose in fill and are you cutting 300mm from the centre of the two ends so 150mm off each piece?
Also if its the above you may find it easier using a router and a guide used for worktops.
Just being nosey
We replaced our table top with a smaller one from O'Leary's in Beverley. We have kept the original one and will reinstate it if we sellI would just buy a new table top to fit to the existing base.
I fit kitchens and I would certainly NOT use a bandsaw for this. The table may have a chipboard or MDF infill, but aside from that the finished edge will be poor.
Try to hire a rail saw (Amazon product ASIN )
and cut upside down, ie from the underside.
If the blade is sharp the finish may well be okay to stick a veneer onto directly, or if not then a router with 12mm router cutter will be needed.
Veneers are available in various woods, or try you local timber merchant and but a piece of solid wood say 5 or 10mm thick and attach using a very good quality glue and some clamps.. Alternatively B & Q will have kitchen worktop edging strips you can stick on using contact adhesive (Bostick).
If you are unsure about all this find a local joiners/carpenters workshop and get them to do it for you, £100 ? should do it.
If as you say these tables cost £1500 I wouldn't want to muck it up.
