popotla
- Jun 5, 2018
- 153
- 106
- 3.5t on Ford Ranger
- Come to Germany! It's great for motorhoming/van life.
Yesterday I set up the ladder to go up there and clean the surface of the big skylight / roof window. However, it's not as easy as I thought; far from it, in fact.
Whatever it is that's on the surface of the acrylic (and is now very unsightly, as seen from the inside) has deteriorated and cracked, and is extremely difficult to get off. I have some window-scratch remover and have tried using it, hoping it would cause the deteriorated surface to soften and thus be more easily removable, but it hasn't worked. With an old butter knife around which I wrapped cotton cloth I've managed to scrape off some of the surface, and have then cleaned this up using the scratch remover. However, it's very slow going and also difficult. I don't want to get up on the roof: am not sure how strong it is, there's nothing to hold onto and anyway I know I wouldn't feel secure up there. (In the past, in order to clean this skylight in the normal way - in other words, get the dirt off it using shampoo and water - I could lean across halfway while standing on the ladder, then do the same from the other side.)
Is there a chemical / some substance I could use to thoroughly soften the deteriorated and cracked surface so that it would come off easily, more or less just be peeled away? Or any other suggestion?
I'm not sure whether my description here is clear. Helpful comments or suggestions will be much appreciated. Thanks.
