Problem with 12v distribution unit
Billyshotts
38
10
Forth, lanark
Autotrail
was fitting 2 batterys and the + and - touch each other the unit shows 12v but when I put light on it drops down to 0 , will I need a new unit
Jan 19, 2014
4,576
14,037
south shields
Chausson 620 welcoome
since 1990
Hi.. and welcome... i see its your first post...
A little more detail required before anyone can really offer any advice...
Are you saying you shortedcout a battery by connecting the positive and negative wires on same battery or connected the positive of one battery to the negative of the second...
And where are you measuring the voltage at to get 0...?
Andy
40,346
38,073
it shouldn't cause a problem. Current can't flow without a feed and return so touching the wires won't give the panel a return route.
the battery OR control panel couldn't be in circuit if you could touch both wires..
Are the batteries charged.?
Billyshotts
Billyshotts
38
10
Forth, lanark
Autotrail
They were fully charged ,auto electric tested it ,he seems to think it's a fuse ,.its a autotrail Cheyenne 2002
Billyshotts
Billyshotts
38
10
Forth, lanark
Autotrail
Thanks for all your help..taking it down to garage tomorrow and get it checked out ..will let you know the results ,,
Billyshotts
Billyshotts
38
10
Forth, lanark
Autotrail
Hi..good news got it fixed,,the fault was underneath on the chassie don't understand why it was not covered up to stop any water getting to it .
36 St. Andrews drive,
Law,
Carluke,
ML8 5GB
SC453365
07719287943
Info@kirkcaravanservice.co.uk
www.kirkcaravanservice.co.uk
