Precautions when welding?
New Forest
Elddis Autostratus
full timing since beginning 2017
Hi, van has to go in for a small amount of welding on sills.
Please could you give me , in basic language, what precautions to take regarding the onboard electrical system,
Many thanks
Silver-Fox
Cheltenham Spa
Rapido
im a not so newbie
Many thanks
Disconnect any earth leads from batteries.
Silver-Fox
Cheltenham Spa
Rapido
im a not so newbie
That's going to make very difficult for Nikki to get it to the place it's going to have the welding done. :whistle:
Ok smart ass :rolleyes:
Make sure the nice man/woman/gender neutral welder remove the earth straps at the place of their employment/self employment :D
Think that covers all bases (y)
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
An experienced welder will keep the welder earth very close to the part of the vehicle being welded. If that is done there will be no effect on the electrics whether you disconnect anything or not.
Nikki
New Forest
Elddis Autostratus
:roflmto: well I could do the Hab batteries before I leave and then make sure the engine one is done when it's on ramp, I also want to make sure that he's going to put the earth strap very near the work on clean metal
sleights
c class
I would choose a different welder and try to find one I trusted to do the job without supervision!!!!
Silver-Fox
Cheltenham Spa
Rapido
im a not so newbie
Agreed but I’m a belt and braces type when it comes to ecu,s.
Just saying :)
West Wiltshire
Long time
The alternative these days to disconnecting batteries is a nice little unit you clamp on the terminals and it takes any surge or power disruptions out.
Not cheap but quite handy as it covers all eventualities and saves frying customers electrics, especially as more things are electronically based these days.
It also saves the hassle of reprogramming radio codes, alarms, satnavs, heaters etc etc (y)
Silver-Fox
Cheltenham Spa
Rapido
im a not so newbie
Agreed but sometimes it can very inconvenient to disconnect everything..
Two earth straps seems little in the way of inconvenience :)
Still everyone’s inconvenient tolerance is different :)
Kendal, Cumbria
since 1999
Indeed:D . I was thinking more of the advice to disconnect the battery hen having to find the radio code etc.
sleights
c class
Depends if they are both under separate seats and if you know the radio code!!!
Geo
Trader - Funster
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Check welders insurance policy----------------------- Carefully
