Hi everyone, I’m new on here, I’m about to embark on a camper van conversion, and hoping for a little advice on a few matters, for now I’m trying to get my head round best way to go with regards power.
So some of the things I’m intending including in my build, a oven, hob, kitchen sink with hot water, shower with hot water, fridge.
I had originally thought I would use lpg for powering most of the above (exception of fridge) with solar panels to provide the power for all the 12v devices (lights, fans, charging devices, etc...) the more I have been looking at things the more I’m wondering if it might be possible to go big on the solar panels and batteries and use these to power everything.
looks like I’d need at least a 3000w inverter for all these high powered devices and even then seems I would need to make sure I only use one at once.
From looking seems like most of these high wattage inverters are 24v so my thoughts were maybe rig 2 batteries in series and use these solely for the inverter powered appliances and another 12v battery to power everything else.
So my question is does this sound like a feasible option? If so does 3 batteries sound enough? What about solar panels what would be sufficient and how would you connect them would you completely separate the two sides of the electricity supply so maybe have 3 panels, 2 for the 24v and one for the 12v? Does having a 24v setup mean it can’t also be connected to the alternator (van battery) for split charging?
Well I’m really excited about joining the camper van world and looking forward to hopefully hearing some of your views, any help and advice will be much appreciated.
thanks.
thanks.
