- Jan 31, 2016
- 2,200
- 4,071
- Hymer B534 DL (2017)
- Well travelled
Is there much difference between a Fiat 130 and 150bhp ? assuming motorhome of similar weight.
The brakes are related to the chassis, not the engine capacity. You can have a 3.5 tonne standard chassis with the 150 engine. The Maxi chassis at 4250 tonne has the bigger brakes, which can also have the 150 engine.Also with the 150 you get better brakes which is noticeable.
I'm fairly certain the 150 option has upgraded brakes.The brakes are related to the chassis, not the engine capacity. You can have a 3.5 tonne standard chassis with the 150 engine. The Maxi chassis at 4250 tonne has the bigger brakes, which can also have the 150 engine.
Can't deny it but I did have to change down gear on BerriedaleHaving the B544 130bhp on 4250kg maxi chassis, it has the bigger brakes.
As Lenny says, the hills are the problem, and living in the Highlands we do encounter the odd hill, problem really is the hills with a bend at the bottom meaning you can't get a run up to them, so on some we end up in 2nd gear.
2 years ago we went up to the Eagles Nest at Berchtesgaden, now that is a hill, we did it mostly 2nd gear and 1st on the bends, didn't doubt we'd get there but thought a bit better spread of power would have helped. When the revs drop all the umph goes too.
I have had a look at a Frankia 640, being very similar layout to the Hymer, but don't really relish losing £20k and having to find another £40k. I'm working on having 62 plate Hymer B544, very well spec'ed and going to 2017 Frankia 640 at asking price of £80k.
We aren't rich but have no debt and would want to stay that way, and £40k is a huge chunk out of our savings.
My thoughts exactly if your using your brakes to the limitAnybody would think we're talking about racing cars
If I went any slower down a mountain road I'd be stationary.My thoughts exactly if your using your brakes to the limit
Slow down
Won't solve the lack of a varible vane turbo which gives you the power at low revs.You could consider remapping the 130 to about 150ish. Most of the benefit would come from the associated increase in torque which would make driving easier at the engine would pull a higher gear.
Yes & what was the 150 is now 160.Have Fiat changed the power ratings on the 2.3 engine as I see some are showing 140bhp rather than 130bhp ?
150 Far better particularly on hills & mountains.So is it like the older 130 or the better 150 with the variable vane ?
