Power to the radio
Wanting to buy
10 years
hi, we have a Fiat Sundance motor home, which has had a habitation check. just thought we would start to prepare to be able to go away (when allowed) and now we can’t get the radio to power on.... never had a problem last year when we went away in it. Is there some anti theft or something? Any ideas, I have looked the manual and it sounds so simple... press the power button.. this doesn't’ work! Any suggestions welcome. Thank you
Is this the standard Fiat factory fitted radio ?
Have you checked the fuse ?
Hi all
this is the photo of the radio..... any assistance to power on appreciated
You need to pull the radio out and check you have power to it usually 2 supplies on red and yellow
Thanks - have tried all suggestions ... holding power for 20secs.... opening /closing doors, connection wires ..... any other suggestions?
Have you put a multimeter over the power supply connections at the back of the unit?
No power, blown fuse or broken wire.
If power, issue with the head unit.
