Well voltage is fixed between 12 and 14.4v so to increase power delivery to a socket you'll have to increase the current capacity with big cable and fuse size. But more info would be good.hi can any one answer a question about increasing power to my plugs in my van conversion
Welcome and can you give a bit more of an explanation as to what you after doing and what you mean by increasing power to my plugs.
Hi what it is I have a few plugs which all work fine with phone chargers and that sort of stuff but I put a tv and a Xbox and they stayed on for about 5 mins then all power went from all the plugs for a whileWell voltage is fixed between 12 and 14.4v so to increase power delivery to a socket you'll have to increase the current capacity with big cable and fuse size. But more info would be good.
Are you on EHU or are you using leisure batteries and an inverter?
Not sure I think batt and inverter
EHU = Electric Hook Up. Is your van plugged into a mains electricity supply via a cable to the van ? Sounds like it's not.
If you have just a battery and an inverter then either the inverter is rated to low in power but more likely battery not charged or knackered.
Hi it is plugged into the mains will that keep battery chargedIf you are using an inverter the phone charger will use very little power and a knackered or discharged battery may be able to cope but the TV and Xbox will use far more power and the same battery won't be able to supply the necessary amps for more than a very limited time.
With everything turned off check the battery voltage with a multimeter directly on the battery.
Should be around 12.4v min
Next, turn on the TV and Xbox and check again.
If the voltage is below around 12v and dropping it's time for a new one.
Presuming you've got a battery charger and it's switched on and the battery isn't completely knackered you should be charging the battery.
Do you have a picture of your set-up?
I don't think it's wise (however well meant) to suggest to this chap (who is clearly not at all electrical savvy) that he starts poking about with a meter (as well as his other naïve comments he said he didn't know what a multimeter was) since he may not even be able to tell the difference between the 12v and the mains circuitry.
Anyway, he seems to have run of Freebie access now.
I certainly think you have a valid point. However, the OP obviously wants to find out more about his van electrics. Measuring battery voltage is a good first step, and quite safe as long as he knows what a battery is.I don't think it's wise (however well meant) to suggest to this chap (who is clearly not at all electrical savvy) that he starts poking about with a meter (as well as his other naïve comments he said he didn't know what a multimeter was) since he may not even be able to tell the difference between the 12v and the mains circuitry.
When you say 'power plugs' can you clarify whether you mean 3-pin mains sockets or cigarette-lighter sockets for 12 volts.hi can any one answer a question about increasing power to my plugs in my van conversion
Don't disagree with trying to help but I doubt that reference to Ah, watts, amps, inverter, AC/DC etc. etc. means the slightest to him (no offence Gene if you're still lurking).I certainly think you have a valid point. However, the OP obviously wants to find out more about his van electrics.
and is also aware of the hazards (spitting, burns, blowing fuses) of inadvertently shorting a terminal post with a spanner or screwdriver. Unlikely I know, especially as it seems his battery is knackered or at least discharged, but there are risks to someone who knows virtually nothing. Just knowing how to disconnect the solar could be a challenge for him.Measuring battery voltage is a good first step, and quite safe as long as he knows what a battery is.
