So a long story here goes. Arrived at Les Gets for some snowboarding in my Hymer 2008 and at 9pm the electrics went dead so had to run the genny till midnight. The next day went to service point and with the engine running filled and emptied everything went to check water level and the panel wiped it self and reset had to reprogram time date all of it. So checked voltage at batteries both 110amps at 12.6v. So next day took them out cleaned all connections checked all the wiring I could, put back togther but everyday I have to run the genny for a few hours to charge the display. It gets to around 7 AH then jumps to 195 Ah 100% charge instantly and will last 10 hours then go flat and maybe only take 20 mins and full again.
The display says charge and also comes up with gas bottle empty warning even though that’s not even enabled. Both batteries are elecocell carbon fibre 110AH and are 10 years old but never missed a beat. So is it the battery’s or the EBL block playing up.
I return in two days but am back in 8weeks so need to sort out, it would normally do 2 days easy in these conditions in the past.
If it is the battery’s what are the best to buy at this time it’s an EBL101.
