- Jan 13, 2020
- 143
- 50
- Hymer B514
- 6 months in a 10m Southwind in the USA (2014). Just bought a Hymer and embarking on a tour of Spain
Hi. Can someone help point me in the direction of a possible issue, I’m hoping just a fuse.... Hymer B514.
I’ve been having so many problems with solar and batteries since I bought my Hymer in Feb, however, having added panels and battery then having gone through a traumatic journey learning stuff and pulling things apart, it turns out that the charger that came with my LiFepo4 was faulty. I was really hoping getting a replacement would solve my issues, but in checking the leisure battery status after an overnight charge, I unhooked all the connections - and there‘s now a more central problem as the steps don’t work and the panel comes on for a second, then an odd noise comes from the Hymer built in controller, and the panel switches off. When I unhooked the leisure battery the water ran out of the boiler - I wasn’t expecting that as it normally only drains if I knock the battery switch in the built in controller, or unhook the car battery (I’ve got a dead switch fitted). It sounds like a blown fuse but who knows.
I’ve checked all fuses in the built in controller (the solar one was dead, I replaced it), knocked the battery on/off switch just in case, reconnected the leisure battery (knowing that shouldn’t make a difference) and checked the 2 fuses near the Leisure battery. Next job is to go round check all fuses in the vehicle; but I’d really welcome pointers.
