But not Portsmouth - Bilbao.
Yet.
Did they just give you money back and told you to go away ?
they have never told me to go away. Not their style.
They did to me once. Not impolitely but they had only one option on offer. Take the money.
full refund of original fare plus an allowance for the travel costs.
I'm pretty sure we did not get that, it was such a panic, no time for cold logic.
Driving down through France was horrendous.
Was going to book for Dec 26 when the sailings come out but thinking about the tunnel instead and driving down. Brittany Ferries should really put one big ship on the Spain run in Winter something twice the size of the Pont Aven which is around 40000 ton, they would have less cancellations then.
Not offended but you clearly miss the point, Brittany Ferries new ships in the pipeline are smaller than the Pont Aven and the Economy ones that they use are smaller still and affected by bad weather. I’m saying that if they invested in a larger vessel then they would have to make fewer cancelled trips.I assume that Brittany Ferries would have a fair selection of available larger ferries in case of bad weather.
Please do not be offended but the image came to mind of a fleet of assorted expensive ferries and crews waiting to take up the slack, moored up at some foreign port.
I've been watching "my" ship, Cap Finistere, stuck outside Portmouth from 20:00 when it should have docked.
And it finally docked at one O'clock. Nearly 5 hours holding off the IOW in 40/50 mph winds. I bet it will pong a bit when we get on Wed.
Size of vehicle depends on size of ferry ports...Brittany need ships that can be docked in all their ports..BUSBY.Not offended but you clearly miss the point, Brittany Ferries new ships in the pipeline are smaller than the Pont Aven and the Economy ones that they use are smaller still and affected by bad weather. I’m saying that if they invested in a larger vessel then they would have to make fewer cancelled trips.
There are only 137 RoPax ships in the world that are in a similar class to the
PONT-AVEN (3,500 Lane meters, 2,400 pax, 185m LOA)
Large RoPax ships are rare and expensive beasts, they need suitable docking facilities.
For those that remember the recent Ramsgate Harbour debacle, one of the problems was the port was not deep enough for modern RoPax ferries, and that was on the assumption they been able to charter a set of three into the service, which they could not.
It's the problem of living on a little island.
The only way off is by ship (or the one tunnel), which means we are at the mercy of King Neptune
Back in the 80's there was talk of a second and third channel tunnel, we should start planning now for the early 2040's, but medium term planning is not something recent governments have been interested in.
Nor are they interested in grand construction projects, HS2 is a classic example of short sighted infrastructure plans, whatever you may think of it, it's 40 years late!
The French had finished there end to end TGV services by the late 1980's, the Germans by the 1990's, even Italy and Spain are way ahead. The UK has hardly even started ! We should be HS10 by now
If P&O can use larger vessels than the Pont Aven on the short hop between Dover and Calais and even larger ones on the North Sea crossing then Brittany Ferries should think more about the Spain crossing in Winter and invest in something man enough for the job.There are only 137 RoPax ships in the world that are in a similar class to the
Pont Aven | Pride of Bilbao | |
Tonnage: | 40,859 GT | 37,799 GT |
Length: | 184.3 m (604.7 ft) | 177.10 m (581 ft 0 in) |
Beam: | 30.9 m (101.4 ft) | 28.40 m (93 ft 2 in) |
Draught: | 6.8 m (22.3 ft) | 6.51 m (21 ft 4 in) |
Depth: | 9.7 m (31.8 ft) | |
Decks: | 10 | 11 |
Installed power: | Four MaK 12M43 diesels, 14,675bhp each | 4 × Wärtsilä-SEMT Pielstick 12PC2-6V 23,000 kW (31,000 hp) (combined) |
Speed: | Cruising: 22 knots (41 km/h) | 22 knots (41 km/h; 25 mph) |
Capacity: | 2,415 passengers | 2,500 passengers |
600 vehicles | 580 cars | |
1,115 lanemeters |
P & 0 use larger vessels than Brittany Ferries to do the short hop from Dover to Calais and back and even larger ones on the North Sea crossings so no excuse
