Portable shower advice
brinklow warwickshire
Romahome duo hylo
since 2016
I'm thinking of getting a portable shower , I have a small camper van, VW size , any help would be appreciated.
PS, I bought a pop up tent, sadly, still up on my shed 🤣
sounds like a good idea but I fear In practice Not. Showering outside is fine but What about the waste soapy Water. It’s not very friendly or environment friendly To the locals.
we don’t have a shower in our van either & we either use municipal swimming pools or book onto a site/aire For showering.
plus heating enough water For a shower In a van Without a boiler can be a problem.
those black bag things you hang outside to heat in the sun can be ok but you need plenty of Warmth its & tricky in the uk.
im sure others will suggest other options.
I painted a 5L water bottle black and put insulation on the back side. It gets warm very quickly in Benidorm. All you'd have to do is put lots of little holes in the lid and hang it upside down 🙃😂👍
Just a thought, may be too much faf but..... skip to about 5 mins 30s. 👍
We had a portable shower system made by Gardener a few years ago. It was easy to erect, waterproof and easy to use with just one bucket of water which a submersible pump went into connected to a shower head and after showering you simply put the pump into the shower tray and pumped it back into the bucket for disposal.
We’ve just bought portable shower, warm water into our folding bucket drop pump in turn on. It connects to our open tailgate.
Wether we use it is another matter!
£15 off Amazon.
Somewhere in my storage is a pump up shower we used years ago in a polypropylene double loo tent. Then a roll up shower tray, which occupied one end of the tent. The other end was the dry/changing area
Heat up water in kettle and add to a gallon of cold to suit or use a couple of the solar bags. Pour water into the tank, screw on hose and pump handle. Pump up the pressure and you get several minutes of showering when you press in the button on the shower head.
It worked really well and we hung on to it to shower the dogs off if we went out when muddy or to a beach. We now have an outside shower in the garage
Not quite what the OP was looking for, but I designed my van with the sink tap being a shower head on a hose - this is long enough to pass through the window
The idea was to use it for removing salt, sand, etc when returning from the beach - it works really well
I should add that when using it I've normally got a wetsuit on, so I'm not being a "Nasher the Flasher" 🙂
It's certainly a knack that you either develop or not
Although I have a shower in my van I very rarely use it, more than happy with a strip wash every day, twice a day when I go for a run.
Normally boil the kettle also instead of heating the water tank, most of the time I am wild camping so water conservation is more important.
We've got one of these quite good and doesn't rely on electric as a back up to our moho shower.
Yes and that one on ebay has the shower head you can lock in place, ours doesn't but a cable tie that we slide up and down does the job to hold the lever in.
colapz do a portable shower with all the fittings and the submersible pump can be charged by USB
We have been using one of these for many years now and find it to be very practical and saves on water consumption when compared to using the built in heating system. Two of us can get an adequate shower out of about 6 litres of water, one near full PortaShower plus a couple of kettles of boiling water (I think our PortaShower only takes 5 litres) We only use the hot water from our built in system in the colder months when we would have the heating on, however, it is noticeable then of the greater volume of water used. The PorterShower is also useful with just cold water to cool down in very hot weather.
