Poor gas pressure on dethleffs/cramer gas hob (1 Viewer)
Lynnie A
3
Has anyone had a problem with the gas pressure to the hob on a dethleffs gourmet centre? One of the burners goes out when you turn it to low. The jet isn't blocked
TIA
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Perhaps the jet is still partially blocked.
Presumably you've alteady removed the 2 Torx screws in the top plate and removed the jet to give it a good inspection and blow through?
Reactions: Jim
43,329
49,441
But don't poke anything through it except a genuine jet probe of the correct size.
43,329
49,441
As its only happening on one burner it can't be gas pressure.
As wagoneers post but could also be a faulty flame adjustment valve.
L
Lynnie A
3
Yes we have already done everything suggested.
thanks for your help so far, any other suggestions would be gratefully received!
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
It's most probably the gas tap itself that is blocked on the simmer setting, a gas tap has a main drilled port for high setting and a smaller drilled port for simmering.
When I was working (gas engineer) I used to find that tap grease had pushed into the ports, or debris from the gas pipework,e.g. Rust, dust and once an earwig.
John.
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
We have a dethleffs with cramer hob.
Had a low burner for three years - sorted when we replaced the burner..
Aug 14, 2013
583
623
Département 87
Profile
Since about year 2000
This is adding to an old post, but for information purposes : . . . .
The two Torx screws holding the burner spreader plate in position on my Cramer hob unit are sized at T6. Once removed, I then had to undo two Philips-head screws and only then could I gain access to the jet. Using a 7mm socket, I removed the jet to allow me to blot it clear with an air-line.
Just one ring had suffered with insufficient flame size and blowing the jet clear solved the problem.
J
