Polar Screens
Zepp
Roaming
7 Years
Called into Minster Products on the way to the Lincoln show I also asked him to make some wiper covers
Nice job. But I'm intrigued as to why you want the wipers covered. I spring mine out, fit the external screen then flip them back onto the outside of the screen.
:unsure:
:unsure:
They are for Spain to stop the wipers sticking to the windscreen in the sun when the screen is not in use
I use wiper blade covers,,rubber and sun dont mix,,mind you not proper rubber in wiper blades now i should think,,BUSBY.
Zepp they look impressive, however I'm intrigued. How are they fitted to the side sliding window and the door? Can you provide a few photos please.
I will take a couple of photos in the morning and I’m hoping my hangover will improve by then
Sliding window ....the material has suckers on one side and Velcro on the outside what is used to attach the screen. You fit the silver bit of material to the window first and lock it into position by closing the window
Door the screen just loops over the door mine needs adjusting it’s my own fault I should of checked ( Lynne told me to check it 3 times lol )
I will call back on Monday after the show
Thanks for the info about to order for my Burstner A class. They have template in stock so easy order
Is it one piece sides and front
Does it use the mirrors at all for more support
GB
Yes its one piece but if it does separate so you can have the solar screen fitted in the middle section
On the a class it does not use mirrors
He was waiting for the black material to come in also the stuff he uses for the solar part of the screen if you want it
