POL Gas connection
cargom
kon tiki sport 596
Hi i am having trouble locating propane bottles with POL connections
i have a swift kontiki sport with a Truma 30mbar valve
so i thought maybe i could convert the POL to take normal propane BBQ bottles, is this possible, and how would i go about it ??
Do you have a bulkhead or bottle top regulator.
If its a bulkhead you would need to bypass it as the BBQ bottle has a bottle top regulator.
If it has a bottle top reg just remove it and fit a BBQ reg.
Another route is change the pigtail from POL to butane with a clip on butane adaptor. Then use standard butane bottles.
Not so, a lot of bbq propane cylinders use clip on 27mm connectors. You can get connectors that are not regulators. Fit one these and the appropriate pgtail to connect to existing bulkhead regulator, if that is what is fitted.
Yes, just change the pigtail for a 27mm clip on adaptor. Generally about £20. Keep the old pigtail for a bit of flexibility.
yes bulk head regulator
ok great thanks for the advice
