Lenny HB
- Oct 18, 2007
- 53,304
- 149,474
- Hymer B678 DL
It won't be that type of earth fault the habitation electrics don't use the chassis as an earth return. The earth's are run from each appliance back to the battery or distribution unit.Thanks for your help! My first thought was an earth issue. I've just finished re-wiring a 1971 beach buggy which was fraught with earthing problems. Finding the earth mounts on a buggy is very easy. Think it's time to crawl under the Lunar.
That type of test is meaningless on a leisure battery, they will have done a starter battery test (CCA) a battery can pass with flying colours and be totally useless as a leisure battery.Thanks Phil, I had one split on my previous m/h. The current ones are absolutely solid. Took the battery out yesterday to Halfords and they ran tests and pronounced it all good. I double checked the clamps when I put it all back together.
