Planning for Early Retirement: Winterizing, RWD Large A-Classes & Heating/Power Setup for Extended European Touring
Ask Carpmart about Agile boxes he spent a small fortune to get his repaired even carries a spare actuator and spent quite a few months off the road trying to find a garage to do the repairs, I am not saying there is anything wrong with the old 170hp engine but the 210hp has ample power for those long climbs.
As you say maintenance may be the key to your success 👍
I did indeed have problems with the Agile gearbox, or indeed thought I did.. It certainly showed codes indicating a gearbox issue, but it subsequently turned out to be the main ECU which was at fault. This was available for Iveco Italy within two days, so no major issue. Most of my downtime was related to booking workshop time in Northern Commercials in Dunstable and their lack of knowledge with the old electronics, flashing the right software etc.
Older electronics on BCM inc wheel speed sensors, gearbox ECU and engine ECU don’t always play nicely together so throw some codes. The fix, now I understand it, is MutliECUscan software to clear down errant codes and negative terminal off the battery for 15mins to reset all memories in the ECU’s
Overall the gearbox works okay and is not better or worse than similar gearboxes in thing like my old E60 M5. I do carry a spare actuator as it’s replaceable very easy with the longitudinal engine and box configuration.
The plus side is I have a motorhome drivetrain which is a whole lot less complicated than more modern equivalents, something I can manage myself, less emissions contraptions and probably a better build than more modern vehicles.
It's really only the two actuators that are likely to cause a problem from my reading.
Mine's only one out of how many hundred! I have a mechanic who is very good and is happy to tackle it if the worst should happen. He hasn't done an Agile before but has done Comfortmatic and rebuilt numerous older engines from motorhomes.
