Pioneer AVIC - F130/F160 - Adding POIs (1 Viewer)
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
We have the above sat nav and very happy with it.
As I have a little bit of time on my hands, you can spend only so much time on a bike turbo trainer, I thought I would investigate adding some campsite POI's. Map updates have to done using a paid service via Naviextra. There doesn't seem to be a clear cut method that is documented for manually adding POIs, so if anyone has done this on the above models I would be very interested in the process that you used.
Thanks in advance.
Swifter
3,910
9,036
Herefordshire, UK
Since 2019
I canā€™t answer the question but this reply will put it up to the top of the list and hopefully somebody can help you šŸ‘šŸ»
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I've not found a way yet.
My new van came with an Pioneer AVIC-EVO1 -DT2
I stick with my trusty old TomTom for all the free POI's
Dec 31, 2010
2,635
5,822
Sunny South Shields
Frankia Platin i7900
Thanks in advance.
Not had this system myself but sure it uses a version of igo is there a sd card somewhere on the system you can remove and plug into a pc?
clanjones
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Ditcha you are correct it does have an SD and I have had a look at a backup and found a folder and POI files which seems to have a couple of other file extensions as well. So not sure if these additional files are created when the POIs are used or what.
Dec 31, 2010
2,635
5,822
Sunny South Shields
Any poi you want to add should be in the form of .klm, and should be put in the folder "iGO/content/userdata/poi", then the icon files for the poi which will be a .BMP should be in "iGO/content/userdata/usericon" if the folder "userdata" is not in the "content" folder then create it putting in the "poi" and "usericon" folders within it.
Here is a list of folder hierarchy and file extension explained
I have some poi for campsites here and abroad I can email to you if you want pm me your email address
poi - interesting points (bars, hospitals, stations ....)
iGO\content\poi
3dl - 3D images of Interest
3dc - 3D images of buildings
_3dlm.poi - 3D images POI
_truck.poi - Parking, service and other services for trucks
_DKV_rich.poi - Of working with DKV card (fuel card for the state freight and bus service)
iGO\content\building
ph - speaks (TTS) street names
iGO\content\phoneme
ftr - Information for trucks - used in calculating routes for lorries (to avoid roads where trucks prohibited, etc.)
iGO\content\map\ftr
fpa - Addressing (street address)
iGO\content\map\fpa
fda - alerts the driver (display active alerts (characters)
iGO\content\map\fda
dem - court
iGO\content\dem
hnr - The base of prepared trails (4 types Fast, short, easy and economical). It helps in calculating the duration of the route.
iGO\content\map\hnr
hsp - Average data on the crowds on roads at different times of the day. Helps in calculating the route
iGO/content/histspeed
zip - 3D model cars
iGO/content/car
zip - skins
iGO/content/skin
global_cfg.zip - information on the country
iGO/content/global_cfg
txt, spc - the place where the measured speed / police radar
iGO/content/speedcam
zip - tutorial for navigating in different languages
iGO/content/tutorial
bmp - Custom POI icons
kml - Custom POI
fjv - Junction view - bmp (bitmap format)
iGO/content/map
fjw - Junction view - svg (graphic format)
iGO/content/map
Global_cfg.zip:
iGO/content/global_cfg/global_cfg,zip
clanjones
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Thanks for that Ditcha, brilliant. I can't get access to the SD as the van is in storage and we can't gain access to it until lockdown is eased.
I may take you up on the POI offer tomorrow, I have packed up for the evening, been driving a desk all day!
Thanks for sharing your knowledge.
Emmit
8,032
17,749
Pilote Explorateur
Jan.2014
iGO\content\poi
iGO\content\phoneme
iGO\content\map\ftr
iGO\content\map\fpa
iGO\content\map\fda
dem - court
iGO\content\dem
iGO\content\map\hnr
zip - 3D model cars
iGO/content/car
zip - skins
iGO/content/skin
kml - Custom POI
iGO/content/map
iGO/content/map
Global_cfg.zip:
Eh!
Dec 31, 2010
2,635
5,822
Sunny South Shields
This is who I use for my campsite poi also includes camping card plus the app is also good.
Jul 27, 2011
21
22
Northants
Burstner Lyseo 728G
20 years
Hi All,
Slightly off topic, but I have Morocco maps from my Trucknav and want to upload them onto my Pioneer unit. They are in "HERE" format as the satnav uses Igo mapping. There doesn't seem to be an intuitive way of doing it, can anyone help or do I take my trusty satnav back to Morocco this winter? TIA.
