grahammay2
Engine failure to limp mode. 22k on clock. Who with authority can say that it's doubtful that the filter was changed at service intervals, or that it had been filled with dirty diesel. I'll wait for the replies please.
AA change the filter, patrolman was surprised at filthy condition and thought it was well overdue. Has run fine since.Why do you assume fuel filter.
What do the diagnostic codes indicate as a possible cause?
Service history? What do the invoices say? Check the date code as above. If you need a report on the diesel you'll need to engage an expert, but they will only be able to tell you the condition of the fuel currently in the tank, not prove where it came from or how long it's been there.
Service history is in place says the main agents Motorhome dealer. Book stamped but no invoices. They blame putting in dirty fuel. Sainsbury's deny any knowledge of having dirty fuel at date & time of purchase.
Also service says every two years whichever is soonest.Depends which year it is but on my 2012 I believe that it’s 25000 miles before it has to be changed, certainly not at every service.
Unfortunately they have no control over the fuel station tanks that they deliver too. So you have no hope unless it died outside as you left from filling up.the fuel companies need to be aware of their product failure.
I agree no need for an extra hobby (or maybe its to try for some compensation?)I'm not happy to accept either, just trying to paint a realistic picture based on my experience investigating vehicle defects and preparing forensic reports following fatal and serious road traffic collisions.
Are you able to prove when the filter was last changed? Are you able to prove that the filter removed by the AA man was the same filter documented as having been replaced in that paperwork, if you have it itemised and invoiced? How can you say that the filter has failed? Surely if the filter was simply replaced and no other work required to restore the functionality of your vehicle, it suggests that the filter may actually have done the job it was designed to do in preventing contaminants getting into the fuel line, but possibly starved the engine due to the amount of contamination. That might mean that the fuel was dirty, but was it the fuel from the garage you last used to top up, or had the dirt already been in your tank and simply blocked the filter at that point due to the progressive accumulation of debris over time? How much fuel did you put in the tank on the last refill before the issue? How empty was the tank prior to that point? Was a sample of the fuel in your tank at the time taken for inspection? Is the same fuel still in your tank? If so, has the new filter been removed to check if it is also showing signs of contamination since being fitted? Have you got a sample of fuel from the garage and pump that you used, obtained independently as soon as possible after the incident?
Your vehicle has presumably been driven since the fault occurred, so even if it is examined and current issues are found, how certain can anyone be that nothing has changed since the time of the incident?
Without being able to answer these and other questions, whilst you may be able to determine the reason for the problem, you will almost certainly fail to allocate blame on a balance of probability or beyond a reasonable doubt.
All I am saying is that you could well invest a lot of time and even money in this, to no avail. You will not get anyone to admit liability without irrefutable proof, and you will struggle to obtain the evidence to support that. You will get nowhere by yourself, you will need independent expert evidence which will cost you money, and unless you arranged for the vehicle to be transported without being driven to an independent premises where it could be examined by an expert without delay, so that it could be ensured nothing material might have changed in the interim, you have already lost evidential value.
Sometimes it is just better to take a deep breath and move on.
