Pegaso 740
roller team pegaso
Has anyone got R/T pegaso 740.
When you go in the garage is there something that has to be drained down in the winter?
I believe the boiler is kn the garage under a box type cover.
There should be an access cover to the dump valve
How do I dump it won’t it leak into the garage
No the valve dumps to outside, through a pipe in the floor , I am sorry I can't seem to load a photo of the valve at the moment for some reason.
If you Google frost control calve you should get the general idea what you are looking for.
If you laying the van up for winter then dump the heater water, and the fresh water tanks, open all the taps and blow them through.
Many of the taps have ceramic parts inside and any amount of freezing will crack the internal parts and you will not be happy come spring
