passenger side electric window not working (1 Viewer)
gwyntaxi
1,150
1,045
,Swansea
hymer starline 655
42yearscaravanning&motorhoming
Hi there all you peeps,
My Hymer Starline 655 Merc chassis, the passenger side elec window (RHD) has stopped working altogether now, apparently it's a well known problem as breaks develop in the wiring harness, anyone out there got any ideas how to locate the harness, all fuses seem ok. TIA.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
On my 2014 the fuse was under the offside front seat. Difficult to see.
Have you properly checked the correct fuse?
If you put the main lights on, does the window switch light up as it should?
gwyntaxi
gwyntaxi
1,150
1,045
,Swansea
hymer starline 655
Hi Sue, sorry for delayed reply only just found your response, no mine does not light up,can't say I noticed that even when it was working, have checked all the fuses I can find,all are intact, it will go down from time to time but it's a bit hit & miss about coming back up, but does out of the blue when switch is pressed,so not a fuse issue as it's intermittent,I think it's more a wiring problem but can't access the wiring after it disappears into the sidewall bulkhead. Many thanks.gwyntaxi.
