Emmenay
- Dec 11, 2011
- 505
- 481
- Swift Kon-tiki 600
- Since 2011
Regarding three leisure batteries in parallel, can some knowledgable folk cast their eye over the below statement and kindly offer their opinion.
It seems quite feasible to me but seems to go against the status quo of connecting solar etc at opposite ends...
Parallel connections involve connecting the POSITIVE (+) connection of one battery to the POSITIVE (+) connection of the next battery. The same goes for the negative side; NEGATIVE (-) of the first battery connects to the NEGATIVE (-) of the next battery. You can connect the POSITIVE (+) of your charge controller and/or DC-to-AC inverter to any POSITIVE (+) point in the battery bank, though it is best to make this connection in the middle of the set of batteries rather than from one end (as shown). Same goes for the negative side; connect the NEGATIVE (-) of your charge controller and/or DC-to-AC inverter to any NEGATIVE (-) point in the battery bank, though a point in the middle is best.
By making the system connection in the middle of the battery bank, the charging and discharging cycles are done in a balanced way. If the system connections are made on the ends, then more charge will flow into the first battery and less flow into the last battery. When discharging, the first battery will discharge first and the last battery in line will discharge last. This is not good for the life of a battery bank
