The water freezes inside, expands and breaks the copper heater matrix.
They can be fixed but are around £150 to replace on ebay.
My advice is to find a slightly newer M'home as this is 34 years old.
Have a look on ebay or M'home Fun classified.
Look out for problems van related but with a caravan on the back.
You can buy something good for 5K to 10K if You are lucky.
if the heater has frozen everything else will have, taps can split pipework will pop apart pump could be broken i assume as the heater is split youll not be able to check any of it
Yes not sure untill I view it!!a few companies have said they can fit a new version but will be about £800 I think I will just boil the kettle for hot water lol ? there’s not a shower in it so only for hot water in the sink!!
Had that very same heater in my Talbot Camelot (7 vans and 20 years ago)...and it froze solid one winter (my fault, didn't drain it properly).
I removed the casing and could see that the 'heater matrix' pipe (approx 10mm dia. copper) had split at the top of the unit.
I carefully 'squashed' the split together, roughed the surface up a bit, then ran a bit of solder over the split...job done, didn't leak again.
