P696D English instructions for IdsWITCH LMP1218-PWM Electronic Distribution Box & fitting a Van Bitz Battery Master (1 Viewer)
Riftzoner
34
54
Whitby Cheshire
Pilote P696D
My new 2021 Pilote P696D has come with a IdsWITCH LMP1218-PWM Electronic Power Distribution Box but the instruction booklet is written in French.
I want to install a Van Bitz ‘Battery Master’ as the vehicle Battery is continually losing charge?
I just want to identify the correct connections before installing the Battery Master.
I’ve tried searching the internet but can only find the French instructions.
Has anyone installed a Van Bitz Battery Master in a P696D & if so do they have any tips?
May 1, 2015
578
428
Caerphilly
Rapido C86 Auto
Since 2014
Hi, I thought Pilote had sorted this problem out on the 2021 model vans . I have a 2020 model and had a similar problem which the dealer is rectifying , under warranty, by fitting a Battery Master FOC. You shouldn't have to sort this out yourself get your dealer to do it for you.
Patrick
Sep 23, 2013
2,579
8,603
Lincs
Globecar Campscout
My French isn't up to much, but p.7 of the manual suggests that the terminal labelled 5 on that page is a connection from the starter battery & terminal 6 is the leisure battery. You can connect the red & brown Battery Master wires to these two & the black wire to any GND terminal.
If you have a multimeter, the Battery Master instructions tell you how to check that the above assumptions are correct.
R
Riftzoner
34
54
Whitby Cheshire
Pilote P696D
Cool, I had a brief look at the IdsWITCH today & came to the same opinion regarding where both battery positives are located but I was unable to identify the main incoming GND (just to ensure a good connection really) as there are numerous ancillary GND’s. Thanks for the response, it confirms I was correct in my findings.👍😉
Nov 21, 2021
47
35
Dorset, UK
Pilote G690D
Since 2020
Hi Riftzoner, I have a 2021 Pilote G690D that is losing van battery charge. Did you sort your problem by fitting a Battery Master?
R
Riftzoner
34
54
Whitby Cheshire
Pilote P696D
I can confirm that the Battery Master appears to have sorted the problem though I haven’t been through a winter with it yet🤔
Apr 27, 2016
6,796
7,835
Manchester
A class Hymer
Since the 80s
BobRivers has posted an English version of the LMP1218-PWM manual, in another thread, post #13:
Nov 21, 2021
47
35
Dorset, UK
Pilote G690D
Since 2020
Thank you
R
Riftzoner
34
54
Whitby Cheshire
Pilote P696D
Thanks, did you make the connections as previously discussed? I also have idswitch LMP1218-PWM.
My Battery Master was fitted by Hayes Leisure who installed it next to the Redarc B2B unit which is located to the rear of the drivers seat base behind the plastic cover. I’ll post a photo when I get a chance.
Nov 21, 2021
47
35
Dorset, UK
Pilote G690D
Since 2020
A photo showing connections would be great. I have purchased a battery master from the fun shop, so any fitting advise while I’m waiting for delivery would be appreciated.
POH
May 29, 2018
1,181
903
Pilote 740c
5 years
Hi i have a 21 plate which also looses charge , did you manage to take photo of B2B location so i can check if mines is the same, cos the wires under side seat are like coloured spaghetti i wouldn't like to chance fitting one with that mess.
R
Riftzoner
34
54
Whitby Cheshire
Pilote P696D
R
Riftzoner
34
54
Whitby Cheshire
Pilote P696D
Basically it looks like the dealer has broken into the two main fused feeds - one for the vehicle battery & one for the leisure battery with the last black lead connected to a Ground lead. The main fuses on my Pilote P696D Evidence are located under the drivers seat base (RHD) plastic panel to the rear of the seat. Lo & behold the Redarc booster is also located there & is flashing away but on which cycle I haven't a clue🤔 as I was advised by the dealer it was disconnected at Fiats request because it adversely effects the Eco function? Getting back to the battery master, the install quality looks a bit iffy, so I intend to tidy it up but essentially both positive leads from the Battery Master come fitted with a fuse carrier & where the dealer has broken into the original cable they've either attached a 'Wagoo' connect or soldered & taped a fly lead to get it to reach the Wagoo. Nothing too complicated. If you've never heard of a Wagoo before it's basically a push fit electrical connecting block. They've good if you use them wire appropriate cable, normally solid core. I hope this helps as to be honest the wiring looked like a rats nest but pretty straight forward once you've figured out which fuse is for which battery. Good luck
