Oyster fitting
North Yorkshire
since 2000
We are still fathoming which way to go re. Tv in new Motorhome. If we buy an Oyster dish we can get one from Caravan Club shop with a 10% discount, but the dealer supplying our MH won’t fit it if they haven’t supplied it. The same applies with Motorhome Wi-Fi , the dealer will only fit if they supply.
I can understand their position but I am hesitant about letting someone that hasnt been recommended drill holes in the roof.
Any recommendations please, preferably North York’s/East Riding/North Lincs.
Ask yourself first if you really need one.
Ask
How much telly do we watch? , if you are just a casual watcher, you may not need a full sat set up, plenty of choices of firesticks , amazon etc. Or just have a radio for news and music.
What type of programmes? If u just want rainy day movies then use dvd player and tv
Do you travel abroad and for how long? This is where sat tv comes in handy , but consider cost if you are only going for a few weeks a year.
if you are travelling for the sun do you need a tv at all? You wont want to be sitting inside a van watching tv in the heat
we use a good tv , avtec, with an integral dvd and an arial that plugs in that cost £15 on amazon.
Great little thing , loads of channels, but we hardly use it.
Removed the dome from our moho, very glad not to have it , they are weighty and bulky and you will need holes drilled unfortunately.
hope this helps…
worth every penny!!!
It's not difficult to do it yourself, just takes a bit of planning. The only hole you need to drill is for the cables, which are covered with a neat little cable gland entry. Everything else is secured using a decent adhesive .... I used one from the sikafkex range after contacting their tech dept to identify the most suitable adhesive, but other funsters have used different makes.
PS - use black adhesive at aesthetically it doesn't go green and mouldy like white adhesive does, unless of course you clean it regularly. Remember to mask the area so you get a neat finish on the roof
Also think where you will be touring, because if it’s in the eu a satellite dish would be better because you would be limited with data usage for streaming.
As someone else has already said in another thread, you can buy a lot of PAYG streaming for the price of an Oyster dish.
And the the weight is a lot less. :giggle:
Again my P.A Speve needs a well deserved thank you for the heads up! :ROFLMAO:
Unfortunately Casper46 a lot of dealers won't fit unless you buy the system from them but if you go down the satellite route (specifically an Oyster obviosuly) then please either give me a call on 01858575928 or email anthony@oystersat-tech.co.uk and I'll happily give you a list of dealers close to your location.
You can indeed, unfortunately watching TV through the internet is a pain in the rear compared to watching it on Freesat. I use both but only use the internet for Prime/Netflix/etc.
I agree and if you don’t have or cannot get internet (no signal) you need a good digital antenna or sat dish, even more so if roaming charges stay capped whilst in EU it will limit your options not having a sat dish😊
Rhino Installs seem to have good reports, their details are in the Reviews section on the top line and may be worth a look at if in the correct area for you.
I used Phil from Rhino installs a few times when he was mobile. He does good work and I would be happy to use him again
Thanks everyone for your input. The sat fitting is organised, I now need a new 12v tv. Reading postings about tv’s it will probably be a Cello as I’m fed up of no programme guide on our little Avtex.
Am I correct that I can view a Smart TV through the Sat Dish, but I can also connect to the internet by a hot spot on my phone?
Please don’t blind me with science as I don’t understand the jargon.
In terms of smart tv I am assuming you mean for internet and channels such as Netflix etc, you will need an internet connection
Thank you both.
We don’t watch Netflix or anything similar, we have a smart tv at home and I like being able to use catch up to see programmes that I have missed in the last week. I assume that I can’t do that on an ‘ordinary’ tv.
Doubtful🤔
I would recommend Rob at Auto-Mate UK as he fitted our solar panels and Oyster Cytrac system. Very neat install and is based in Lincolnshire about 5 miles from Brownhills MoHo's at Newark on Trent.
