Oyster dish (1 Viewer)
P
philfish
68
14
anglesey
autotrail arapaho
since 1992
sorry sallylillian but southern Spain is a long way to come to pick up the dish.
Anthony OysterTech
Oyster Satellite Technical Service
Jan 25, 2017
319
502
Welford
Don't own one yet
Since 2008
As long as my flights are covered I'm there! (y)
Anyway, morning Phil. Can you explain the problem at all? I might be able to assist from here. If not then there are Oyster representatives in Spain and Portugal but they may be a small distance from you.
Anthony OysterTech
Jan 25, 2017
319
502
Welford
Don't own one yet
Since 2008
Ok, just saw your wall post.
Sounds to me like the bolts have come loose.
Shouldn't happen because they are torqued up at the factory before being tested however they could have been undone at some point that we're not aware of.
Firstly, do you know which system you have exactly? I would say it's either an Oyster Vision III or an Oyster V Vision. You can normally tell by the stickers on the dish. If there is no V on it then it's a Vision III system. Once I have this info I can advise.
P
philfish
68
14
anglesey
autotrail arapaho
since 1992
thanks for the reply Anthony will have a look at the bolts when i find a ladder then i will get back to you CHEERS
Anthony OysterTech
Jan 25, 2017
319
502
Welford
Don't own one yet
Since 2008
Hi Phil,
No problem. If the bolts are loose make sure the system is in rest mode before you tighten them.
If not you'll get a multitude of errors.
Easiest thing to do is do hold down all four buttons on the controller until the system goes into reset.
Watch the screen and make sure it sets and then goes into standby (blank screen).
Then tighten the bolts (60nm if you have a torque wrench) and then try turning it on. Hopefully that should cure the problem.
I'll wait to hear how you get on.
P
philfish
68
14
anglesey
autotrail arapaho
since 1992
morning Anthony the bolts had come loose do you have a contact number so i can discuss my problem.
ps can't afford the air fare to Spain.
Anthony OysterTech
Jan 25, 2017
319
502
Welford
Don't own one yet
Since 2008
Thank you all.
As Elamessa stated the tel is 01858575928 however after today we will be closed until the 22/10 due to exhibiting at the NEC. I am available during the show on 07979745688 but may not always be able to take a call. If you get my voicemail please leave a message and I will call you back as soon as I can.
