Outside window seal
winchcombe
swift sundance 630g
Hi all need a window seal for a side window on my swift sundance anyone give me an idea where to look? cant find it cheers matt
Thanks for that so many seals my leaks in very stormy weather but can't see where from drips inside middle of the window ,will take another look.
Is it the dinette window?
yeah the large one on drivers side,not realy sure where its coming from will get the hose pipe on have a look?
Mine started to leak ,but not always which was confusing
Found that at certain angles water runs off roof directly down that window washing any dirt/debris off roof and into top edge of window
Later when you open window it pushes the dirt into the seal and prevents it sealing properly
Slipped the window out, cleaned it all well and then it was ok
Worth a try
That sounds worth ago i was looking at doing that,its only when its bad rain and when its on a slope so could be it cheers for youre info again (y)
Use something like this to clean all your seals and rubbers
I've found the side window has worked better and wet and forgot on all mold and algue build up has helped to reduce growth and reduce what's there without scrubbing
