WESTY66
- Jun 17, 2017
- 9,107
- 27,342
- Carthago Chic C-Line
- All the gear, and no idea!
I just kick my crocs offTypical Yorkshire man, too tight to buy shoes.![]()
They do Neismans as well, so that's a good thing to hear.I was in Reliance today for the vans first damp check, I can't believe we have had it a year.
Interesting talking to the guys there although Carthago's aren't without problems they were saying of all the van they work on Carthago's are the best built and the only ones they would recommend.
For anyone who doesn't know they are just a service centre and they don't sell vans.
Interesting of the newer Pilote 3.5t Motorhomes they have had to replace the inner floor as far back as the bedroom on 9 vans due to undue flexing, it's an 80 hour job as all furniture has to be removed.
Saw my electrics and asked if I wanted a job.They do Neismans as well, so that's a good thing to hear.
Handy them being local to me they do most of my stuff - I certainly trust them.
Blimey, remind me not to go thereSaw my electrics and asked if I wanted a job.![]()
Might have been so he could work off the what he owedBlimey, remind me not to go there![]()
Ey up lad, go easy on us TykesTypical Yorkshire man, too tight to buy shoes.![]()
Ours are slightly different being a C class. The German dealer spent a lot of time and effort resolving the over cab cupboard his words “if you had seen it from the factory you’d have rejected” they fitted a custom alu extrusion to resolve the poor factory joinery.These ones.
Strewth Lenny, you're not related to Sterling Moss are you?Your doing well I only get 24 to 26.
I forgot I also adjusted all the cupboard door handles and latch keeps to stop any play, and added a few foam pads where needed.I’ve adjusted the hinges and fitted a couple of foam pads to keep tension on the latch.
Neil
Can't get anything like that no matter how carefully I drive.Strewth Lenny, you're not related to Sterling Moss are you?My hubby likes a bit of speed but we still get at least 28 out of ours up/down mountains etc.
Hopefully will come up a bit with more miles - ours is on around 10,000 and is still slowly improving - there was a firmware update a while back which helped a little, but I think we might be just on 20 now. Was 24 ish on the Merc E line, so your's does seem low.....Can't get anything like that no matter how carefully I drive.
Most of my driving is in normal mode, found Eco unusable too sluggish and only use Sport in hilly districts.
Spray the springs with silicone, worked on ours.Nielh and Manxcat any advice on what I can try to sort out the creaking front cupboards ? Seems solid but the creaking over my head is very annoying.
Our step retracts when the engine is started BUT only when the door is closed, it's not a Carthago though.Because, if the passenger is just going out, when the driver starts the engine ......
Obvious when you think about it.
At Adams Morey at the mo, gearbox update being done.Hopefully will come up a bit with more miles - ours is on around 10,000 and is still slowly improving - there was a firmware update a while back which helped a little, but I think we might be just on 20 now. Was 24 ish on the Merc E line, so your's does seem low.....
ASK em to free the brakes offAt Adams Morey at the mo, gearbox update being done.
Only done 7000 miles in the year as we had to cancel our spring trip.
Maybe it's because they are more solid, that they resist movement a bit more and don't flex causing creaks? I was surprised how noisy ours was when we first got it coming from a Dethleffs A class, which was pretty quiet.Must admit it creaks and rattles far more than any of the Hymers we have had, which is surprising as it is much more solidly built.
Most of the noise in ours is bad stowage, but the dash extension seems poor on bad roads and the passenger seat if empty, and I guess a little screen blind (chain thing) or drop down bed, not sure which. One day I will wonder round while Julie drives, then I can add a bit of neoprene foam tape in the right places. Haven't tried having the sliding doors closed etc. Overall, other than the dash, it doesn't irritate me as much as the driving/directions/parking advice system which cannot be turned off.........Must admit it creaks and rattles far more than any of the Hymers we have had, which is surprising as it is much more solidly built.
Only running around 3800kg, last van was running at 4300kg and I got better consumption.Lenny HB, I know you've uprated your MH so are you still carrying a load ofjunkprecious cargo around? Might be why you're getting crap MPG although my money's on a very heavy right foot!![]()
I used to think my Malibu was completely squeak and creak free until 12 months ago when after much nagging from my family I bit the bullet and got some hearing aids and discovered it squeaks, creaks and rattles like a rattlesnake!Must admit it creaks and rattles far more than any of the Hymers we have had, which is surprising as it is much more solidly built.
In your defence Lenny HB a torque converter box (your ZF 9 speed) loses a little power through the torque converter (all the oil and friction plates etc) therefore maybe a little more down on the pedal to do the same Motion forward as a dry clutch set up (comfortmatic) hence using a bit more fuel ( your 9 speed ZF)Only running around 3800kg, last van was running at 4300kg and I got better consumption.
My right foot only weighs 100kg.![]()
Keep up son, it's a 9 speed ZF box.In your defence Lenny HB a torque converter box loses a little power through the torque converter (all the oil and friction plates etc) therefore maybe a little more down on the pedal to do the same Motion forward as a dry clutch set up, hence using a bit more fuel.
That’s my theory unless someone will correct me with up to date knowledge of the latest TC box’s but that’s what I learned in college in the early 80‘s![]()
