Good thing we are all different. Hadd the microwave taken out the Mizar as we rarely use one at home, and have never missed one while away. Our full cooker gets used often, especially in the winter, as does the remoska any time of the year. Neither remoska nor microwave would be of any use when off grid, for me full cooker is a godsend. Have often thought of compromises that would need to be made if we downsized though and have decided I could cope much better without an oven and microwave than I could without a toilet compartment. Can't wait to see the finished article.Good to hear your thoughts @scottie , thank you. I never used the oven in my larger coachbuilt in 3 years, don't see it changing now!
Errm... Yes I have to agree with you on that!decided I could cope much better without an oven and microwave than I could without a toilet compartment
They haven't even got the van yet Debs. Once they have it, they take a week to build and another week to test it.
I was away!!! (chatting with my dad, not snoozing in the sun). Meanwhile - I deny EVERYTHING for now.Mmm you didn't deny WildAx Pulsar, and it does have a wheel on the back!!
the 80 w panel matches the 100 amp battery. There's no space on the roof for any more than the 80 w so I've ordered a second leisure battery. Seems the 3 batteries will look after each other.
You're right Brian I don't really understand the electrics, I keep trying but it just doesn't go in. But I was fairly sure I'd understood that I'd probably be ok with the 80 w as I'm not planning to be static for long (maybe a few meets).This seems a constant theme on here, add another battery without working out how to charge it.
Some numbers, bright Spanish sun and you might get 80/12= 6A ( very rough ).
Half empty 100Ah battery as is the norm, you need 50Ah.
You have 6A so 50/6=8hours of good sunshine.
Now you add a second battery so the numbers are 100/6=16hours. So way over a day to recharge.
What I am saying is you can fit 10 batteries but all the electricity you have, parked up, is the 80W of solar.
If you drive a lot the picture changes as the engine does some charging, it depends on your lifestyle.
As a matter of interest we have 100Ah and 100W of solar and if we have to charge the bikes when off hook it gets very very tight.
that explains why my van battery has failed after 7 years never been charged. Dont know why ive been dragging an alternator around all that timeIt is worth noting that an alternator is not a battery charger and it cannot fully charge a battery, no matter how long you drive the vehicle for.
It's main purpose is to supply the vehicles electrical equipment when the engine is running. To fully charge and condition the batteries you need to be on hookup and let the charger do it's stuff.
Once a month is recommended, This will give better performance from your batteries and should extend the service life.
Those type of charger are needed because solar works all the time and a vehicle could be on EHU for months. However, an alternator only works when the engine is running but given enough time it can certainly recharge all the batteries. How do you think the vehicle battery in non-MHs is kept charged?So CTEK, Stirling, Victron et al are conning us with their intelligent chargers and solar products as we need is an alternator.
I don't want to put in the second leisure battering it's of no use.
efforts to educate me Brian
You're moving the goal posts now. It was the statement the alternator can't fully charge the leisure batteries I took issue with. Whether this is the best way to do it is a different issue. My Victron solar controller takes the batteries through a daily charging cycle which the vehicle system won't. However, there are undoubtedly numerous MHs without solar and which are used off EHU and their owners are quite happy with the results they get charging the batteries by going for a drive. It probably shortens the life of the leisure batteries but I wonder by how much?The alternator is capable of replacing the small amount energy used in starting the vehicle. It's not designed to charge and condition a fully depleted leisure battery.
An interesting point about the economics of solar.However, there are undoubtedly numerous MHs without solar and which are used off EHU and their owners are quite happy with the results they get charging the batteries by going for a drive.
IIRC - It's been generally recommended here that first add an extra battery, then get solar.
A solar panel, professionally fitted, is usually around £500
A 100amp leisure battery about £100
But the bottom line is all this depends on sunlight and your usage of electricity so guesswork.
I would buy with one battery and add one later if needs be but even then you fit the second and then find out the, I must say pathetic, 85W panel is not enough.
In a few days we will be at Chester with 100W and 100Ah battery, we will survive the 4/5 days. If I were to improve it I be fitting another panel rather than a battery, it all goes pear shaped if you can't get the electricity in.
Now, let's have a think, a 5.5m van, I think half a meter would take a 100W panel nicely
to just 'survive' with only one battery and one 100w panel???
Seriously ?If you listen to and not analise the crap posted on here you will either kill yourself or go mad.
Justify that statement you just made.
So what?So what.
One generates electricity, the other stores electricity, they are not the same. I suspect a professionally fitted price of a battery would be way above your estimate.
Sorry to have a go at two of your posts but whilst the subject is very active we might as well get it right.
If indeed there is any "right" because it's all down to individual users.
And is it too much or about right Stephen?Indeed I know the price the OP's converter charges for an additional battery .
Well, it's just a little bit more than I paid a local place to have an extra one fitted in my old van... (probably £10+)And is it too much or about right Stephen?
My thoughts too, I'd have put up with a lot more than £10 difference for exactly those reasons. Thanks.Well, it's just a little bit more than I paid a local place to have an extra one fitted in my old van... (probably £10+)
- those are the reasons I'm having their solar too, rather than shopping around for the absolute cheapest deal.
- But I'm having one as an option on mine, because it's easier to have it fitted at time of collection,
- it'll be a neater install as the battery box/compartment will be adapted to take two batteries side by side.
- And it's one point of call if any glitches in the electrics, no pointing at third parties
