R
Robert Clark
What do you make of this ?
Not for the motorhome, but for your house
Why not? Let's play with a few numbers. One of those units stores up to 5.5 kWh of heat.Not for the motorhome,
Yes, with a vacuum flask wall arrangement like the gel stuff has, what's to say the standing heat loss would be any higher. But perhaps the gel stores more heat, I know it takes a lot of heat energy to melt ice so changing state might be the key.KIS. Why go to all that trouble and expense when a simple immersion heater used as a dump would do the same job and a damned site cheaper.
That technology is already in use, but it takes up lots of space, whereas the Sunamp it tinyI guess it’s an down to cost, but I have thought before why not have a large tank under the floor which is heated by solar in the summer and used to heat the property in the winter.
The problem with the simple immersion heater in a tank is that on a dull/winter day the water is warm but not hot. It's a breeding ground for bugs, you're likely to get things like legionella in the water.KIS. Why go to all that trouble and expense when a simple immersion heater used as a dump would do the same job and a damned site cheaper.
Exactly my thoughts. You can get solar hot water installations (vacuum tubes on the roof usually) which also claim to meet most of your hot water needs - but they only mean the hot water coming out of the tap. They do next to nothing in winter for the central heating. A big thermal store (giant hot water tank) will allow central heating water to be heated but again, not much use in winter. If you want to have solar powered heating a ground source heat pump possibly in connection with a big battery might be more effective but generally the house needs designing from the ground up for this sort of solution - underfloor heating and high levels of insulation.Anyone notice the big mistake the presenter made? - He said saves 75% of your gas bill over a year, should have said saves 75% of the gas use for water heating which won't be much compared to the heating bill.
Interesting but can't see it ever going to pay for itself.
Think thats referring to the magic material inside, ie the temperature required if using an external heat source to feed into the unit, not the melting point of the unit itselfMelts at 58c according to their website.
https://acarchitects.biz/self-build-blog-sunamp-heat-batteries/
