- Jul 18, 2009
- 11,145
- 17,741
- HYMER B644
Amps represents the amount of electric current flowing.Watts and Amps?
Why would anyone need to run a hairdryer for 30 minutes, nobody has that much hair, even SWMBO s only takes a couple of minutes.Amps represents the amount of electric current flowing.
Watts represents the amount of power available from that electric current.
To get watts, multiply amps by volts.
Taking 4 amps from your 12 volt system is (4x12) = 48 watts
Taking 4 amps from a 240 volt hook-up is (4x240) = 960 watts
To power a 1000 watt hairdryer from a 12 to 240 volt inverter takes (1000/12) = 83.3 amps plus a bit for inverter losses, say 90 amps.
If you ran that hairdryer for 30 mins that would reduce your 12 volt battery by (90/2)= 45 amp-hours, which is about all the usable capacity of a typical leisure battery.
Take her for a ride round the block, put your foot down a bit and get het to stick her head out of the passenger window..hair dry in no time
