JulieJuJu
- Jul 5, 2021
- 5
- 8
- c class
You'll need it this summerHi, we’ve just bought our first motorhome and are total novices. We’ve booked a few trips with 10 amp hook up. My question is, would a 500 watt oil filled radiator be ok with the level of hook up we’ll be getting or will it trip? Thank you in advance for any responses....regards Julie
Thank you so much for helping me, it’s much appreciatedYou'll need it this summer
Thank you so muchYou'll need it this summer
Welcome to the Fun! Elaine and I are a pair of low tech meanies; we use a pair of hot water bottles that can be filled from the gas kettle; and the heating control involves kicking one, or both, of the bottles out of the bed ...Hi, we’ve just bought our first motorhome and are total novices. We’ve booked a few trips with 10 amp hook up. My question is, would a 500 watt oil filled radiator be ok with the level of hook up we’ll be getting or will it trip? Thank you in advance for any responses....regards Julie
Hi, I’ve bought a low watt kettle. It is a motorhome with a heater & airflow system but we just wanted something we could leave on to air the place for when it’s chilly & we pop out for a bite to eat on an evening (obviously not going out in the motorhome) but also wanted something safe to use for an awning, we’re not keen on fan heaters, find them temperamental. Thank you for helping me. I’m sure i’ll be posting many more questions on here in the coming weeksYour 10A hookup will allow you 2300W. Just add up everything you need at once and turn things off if you'll go over. Water heaters will take a lot. A standard domestic kettle goes up to 3000W these days, so you might want to choose carefully.
However, you do call it a "motorhome" rather than "campervan". Typically, these will have heating built in and you wouldn't need to bring along additional heating.
As already mentioned….it’ll be perfect for your suggested use.Hi, I’ve bought a low watt kettle. It is a motorhome with a heater & airflow system but we just wanted something we could leave on to air the place for when it’s chilly & we pop out for a bite to eat on an evening (obviously not going out in the motorhome) but also wanted something safe to use for an awning, we’re not keen on fan heaters, find them temperamental. Thank you for helping me. I’m sure i’ll be posting many more questions on here in the coming weeks
Me too and the still warm water saves a bit of gas when I return it to the kettle to make my morning cuppa.Welcome to the Fun! Elaine and I are a pair of low tech meanies; we use a pair of hot water bottles that can be filled from the gas kettle;
Oh, I couldn't do that. Doesn't it develop a taste?Me too and the still warm water saves a bit of gas when I return it to the kettle to make my morning cuppa.
I need two mugs first thing of strong China tea with two sugars in which you could stand yer spoon up before basic speech returns and it's absorutley rubbery.Oh, I couldn't do that. Doesn't it develop a taste?
That’s exactly what we do in Spain in winter. The only time we turn on the gas central heating is if we have wet coats then we hang them in the bathroom and open the vent fully and usually everything is dry within half an hour. We make sure we keep the vents closed in the rest of the van otherwise it just gets too warm!The problem we have found is that are boiler is under the bed so It is always warm when the heating is on. A small oils filled radiator in the front of the van will prevent cold surfaces and so reduce condensation
