Oh dear, wonder what the cost of recovery was????
Yet a bigger truck is able to navigate the road🤷‍♂️🙄
Rear wheel drive probably. Hard to see how the MH was stuck but possibly the camber of the road meant they lost traction on the front left. Then why couldn't they reverse?
Easy to be critical without being there but hard to think driver error wasn't a factor.
I love driving on roads like that but you have to take your time and take the bends as wide as possible, waiting if necessary until it is clear and you can drive on the wrong side of the road.
Hopefully the bill wasn't too big. :)
I would have thought the sign would have prohibited van length not weight 🤷
Graydo
But he came down backwards.....?
Just the one bend then that’s tricky then?
They usually don’t put signs up for no good reason👍 Passo Gavia has signs (no vans) and that is a wicked pass but I saw the council twin wheel transit up there trying to pass an opel Astra and boy was he close to the edge of a huge sheer drop😁😁
I've had exactly the same thing happen in a RWD medium wheel length transit, one wheel up in the air and no traction. I just rolled back and took the bend on the wrong side of the road as i could see if anyone was coming down.
Graydo
It's not the length, its the wheel base.
If you look at the Swiss post busses, the rear wheels are very close to the centre of the vehicle,
which means despite their length they can turn very tight hairpins
Got that t-shirt in Italy. Luckily a 30 point turn got me out (twice on the same stretch if road within a couple miles 😳)
The vehicle geometry is all wrong. A very long, and low , rear overhang. Means lower proportion on weight on front driving wheels; even if the back corner doesn't ground, he'll have to cut the corner a bit to avoid tail swipes. Add tight turn and diagonal camber, his outside front wheel will be spinning for fun, and the other one not enough grip to pull the whole thing round, even if it does have traction control.
Built for the central European plain, not alpine passes :rollingeyes:
Apparently, it’s not the length, but how you use it.
Defo a daft attempt at making friends I think.
I have done this.
Only difference is mine was worse. Back and front both hitting the floor.
I managed to use the traction plus button and inch it out. Crapped myself!
It was dark, raining, only sign was a homemade one warning of a sat nav error and I thought it was the same road I had come down so ignored it.
The motorhome was likely stuck due to loss of traction.
The camber on a steep hairpin like that twists significantly. I bet that left hand front wheel is hanging in the air.
I found it was the right front tyre that couldn't grip due to the steering lock required to get around the bend. I needed to get the back of the moho further round in a 30 point turn to reduce the steering angle until enough rubber could get on the road to give traction. All great fun in a Comfortmatic with plenty of local Italian encouragement 🥵
I had a few interesting moments on icy corners like that when driving a full sized Coach with passengers, up the mountains on the Ski trips! 😱 😄
There is a very real possibility in that case that the full recovery cost could be more than the value of the MH.
Commercial recovery with Full size recovery equipment isn’t cheap, and having worked there for a brief period I’m sure the Swiss justice system doesn’t hold back with drivers who block the road because they don’t adhere to the road signs.
Perhaps their equivalent of Driving Without Due Care and Attention.
