Been thinking about getting some solar panels for home to recharge my power bank, any recommendations?
BITS4REASONS NEW MODEL MAYPOLE MP374B 200-250V 16A UK HOOK-UP LEAD 3 PIN/MAINS ADAPTOR CARAVAN MOTORHOME TRAILER CAMPING CAMPERVAN WITH EASY FUSE REPLACE PLUG £11.99
Cadac Safari Chef 2 Pro QR BBQ - Black £139.95
Bosch H7 Maxibox Halogen Bulb Set for Car Headlights and Lamps, 12 V - Socket Type PX26d - Spare Bulb Box Containing the Most Essential Bulbs and Fuses £10.28
NOCO Boost X GBX45 1250A Jump Starter Power Pack - 6.5L Petrol, 4.0L Diesel | UltraSafe: Spark-Proof & Reverse Polarity Protection, 60W USB-C Power Bank, 12V Battery Booster for Cars, Motorcycles & More £119.48 If these are for charging a power bank are you looking for the portable fold up type which could also be taken with you in a van?Been thinking about getting some solar panels for home to recharge my power bank, any recommendations?
Looking at installing them at home, so rigid panels would be best I think.If these are for charging a power bank are you looking for the portable fold up type which could also be taken with you in a van?
Well, that should let you run a kettle or air fryer, and charge phones and laptops, but for how long will depend on how big a battery it has, as you can't rely on a lot of solar in the winter. If you have gas you could cook and boil water with that instead, but gas central heating will not work during a power cut. You might be able to power your router from it too to maintain internet access, assuming the supplier's equipment is not also disabled by the power cut.We frequently get power cuts in the winter months so hoping to be prepared for long power outages.
Yes, you make some good points, thanks. Looking at these solar panels to charge the power bank. Are the any good at £234 for 800 watts?Well, that should let you run a kettle or air fryer, and charge phones and laptops, but for how long will depend on how big a battery it has, as you can't rely on a lot of solar in the winter. If you have gas you could cook and boil water with that instead, but gas central heating will not work during a power cut. You might be able to power your router from it too to maintain internet access, assuming the supplier's equipment is not also disabled by the power cut.
A lot of people are starting to think about this now, due to the recent close call on a grid collapse, and threats from Russia. A powerbank is a limited, but much better than nothing solution, and it is a good idea to explore using solar panels to try to top up the power bank.
However, I think the only really effective solution is a large dedicated house battery and inverter, together with solar panels and a whole house switch or gateway which allows the system to keep generating power for the house during a power cut. Without a gateway or equivalent, for safety reasons, house systems are required to shut down once the grid is lost.
It is impossible to tell really. Seems a very good price if they actually meet the output spec. You would need to check the electrical spec of the panels (22V and 12A max output) versus the spec of the power bank to know if they are compatible with each other in terms of any voltage or current limitations of the solar controller built in to the powerbank. This might dictate whether you connect the panels in series, in parallel, or a mixture of both.Yes, you make some good points, thanks. Looking at these solar panels to charge the power bank. Are the any good at £234 for 800 watts?
4 x 200 watt panels
We use essential cookies to make this site work, and optional cookies to enhance your experience.
